How do I Remove radiol from 1996 320SL - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-07-2009, 04:49 PM Thread Starter
Date registered: Feb 2007
First of all, Thank You for your help in advance!
I am trying to remove the radio from my 1996 320SL. I know it should be simple, but....
Any help you could provide is appreciated.
hlavender is offline
post #2 of 2 (permalink) Old 11-08-2009, 05:14 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
Most if not all MBs use special "radio" removal tools that are inserted into the slots on the sides of the radio. The tools are also used to remve the HVAC controls. When you remove the radio it will "lock" so you will also need the code to unlock it when you re-install it.
Any audio shop should be able to unlatch it for you, and a dealer should be able to give you the code if you go in and show ownership. The tools are available on line from various sources.
Peter Guenther is offline
    320SL myjohnny General Mercedes-Benz 2 08-29-2009 03:28 PM
    Remove door sills w124 1996 hariratan W124 E,CE,D,TD Class 5 07-10-2009 10:12 AM
    How to remove 1996 c280 instrument cluster astephennig W202 C36 AMG, C43 AMG 2 11-23-2007 12:58 PM
    how to remove hardtop on SL320 1996 luant16 R129 SL-Class 4 01-08-2007 12:25 PM
    1996 e320 - How Can You Remove Interior Door Panels Guest (MBNZ) W210 E-Class 2 09-25-2001 04:14 AM
