1995 E320SE ASR Activating Randomly? Help? - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-07-2009, 03:50 PM Thread Starter
Date registered: Nov 2009
My 95 E320 has about 140k miles and generally drives well, except for inconsistent acceleration during around town driving.
Recently, my ASR light came on after a short drive and I could not accelerate from Park-to-Reverse-to-Drive whatsoever. The peddle went flat to the floor with no response. I turned the car off and let the engine settle for about 5 minutes and I then could drive normally.
Over a week later, the car inexplicably pulled the same stunt in a crowded parking lot. The ASR light came on when I pulled out and I could not accelerate. I had to leave the car for about an hour and came back and drove home with no issue.
Would this ASR issue also affect my regular acceleration? I have no idea where to start with the ASR.
My Check Engine Light has been on for a long time, even after extensive repairs (OVP relay, purge valve, alternator, new drive belts, rebuilt A/C compressor, etc.) that only briefly turned off the CEL. I eventually just ignored the light because my research indicated no major issue. Is the CEL related to the ASR malfunction?
Computer Codes?
Wiring Harness?
Alignment / Tire size?
Thank you kindly for any help!!!
ConfusedByMyBenz is offline
post #2 of 4 (permalink) Old 11-07-2009, 06:46 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 352 Post(s)
a fault that triggers the CEL can give you the problems your experiencing by putting the car into the "limp home" mode.
My experience is that the ASR light won't do that IF the light only comes on when you accelerate and it detects slip. However, the ASR light staying on indicates a failure of the ASR system which could also cause the problems.
Pull the codes and see what it shows.
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #3 of 4 (permalink) Old 11-07-2009, 06:59 PM
Triggerhappy's Avatar
Vehicle: 1978 240D
Quoted: 41 Post(s)
Is the ASR malfunction light on? Also, if the problem occurs shouldn't turning the ASR off solve the immediate problem?
Triggerhappy is offline
post #4 of 4 (permalink) Old 12-19-2009, 12:45 PM Thread Starter
Exclamation PLEASE HELP!!! ASR Reset???
What is Limp Home mode? My ASR light has come on now with increasing frequency and usually goes off after I turn off the car.
However, this recent time, the ASR turned on and stayed on, refusing to let me accelerate whatsoever. I cannot even go reverse with any acceleration. I put the pedal to the floor with no response. The snow chain light accidentally came on ( l never use this in So. California). My car is stuck in a parking lot at work, so this stupid ASR is ruining my life.
The engine seems fine, but the authoritarian ASR is acting as the king of its domain, pointing its scepter at the lowly serf (me) and disabling all driving of the vehicle.
How can I reset the ASR? Would removing and reinstalling the battery reset the ASR computer issue? Is something else at play? Any advice on a battery reinstall?
I had OVP, alternator, A/C compressor, purge valve work done since January if these affect the issue.
    ASR issue -1995 SL500 kickstarter69 R129 SL-Class 9 12-21-2008 11:59 PM
    ASR on all 1995 E320 special editions? alexnatt W124 E,CE,D,TD Class 12 08-10-2007 08:56 AM
    ASR-ABS 500sel 1995 Larrysd W140 S-Class 9 12-27-2006 09:13 PM
    1995 s600 coupe ASR Questions espo5166 W140 S-Class 2 12-20-2005 02:57 PM
    New AM/FM/CD for '95 E320SE? chandlerbenz W124 E,CE,D,TD Class 8 05-07-2004 03:29 PM
