Jump Start Gone Bad......... - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 11-06-2009, 12:35 AM Thread Starter
Date registered: Apr 2006
I jump started my 92 500 R129. I connected the terminals WRONG (pos to neg). The battery on the other car started to smoke. I discconected the cables. I jump started my R129 the propper way, and my instrument cluster was not working. I replaced the fuse and everything works except the MPG guage.
Now the car is hard to start, idles very rough, sometimes turns off. I can drive it, but it feels like its driving on 4 cylinders NO POWER. Missfiers bad.
Please any info will help. I have replaced the battery but still the same problem.
s500newb is offline
post #2 of 3 (permalink) Old 11-06-2009, 02:33 AM
gamble's Avatar
Date registered: Oct 2009
Vehicle: 420sel
jumped....
first of all, welcome.!
second, next time you jump start a car, put the negative cable of the car that needs jumped on a part of the engine or something that is grounded to the battery. do not put the negative directly to the terminal. doing so could possibly save $$$ and time by protecting your electrical components from frying .... or something along those lines. i just know that its safer.
third, what probably happened was what i said above. it could be a problem with a relay, sensor or computer... you might want to do a search on the over voltage protection (ovp) relay. im not sure... but if you do a search im sure someones done or had the same kind of problem.
best of luck !!!
Gamble says... does it really matter.?.?.?
gamble is offline
post #3 of 3 (permalink) Old 11-06-2009, 11:55 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
    REAL BAD IDLE AFTER BATTERY JUMP slickqrickq R170 SLK-Class 22 06-30-2009 09:24 AM
    how to jump start?? PLEASE HELP grider G-Class 3 05-06-2009 07:19 PM
    How to jump start? beastia R129 SL-Class 16 12-24-2007 12:56 PM
    AFTER JUMP START? FASTRMK700 W202 C-Class 3 10-09-2007 01:49 PM
    Jump Start? FASTRMK700 W202 C-Class 2 10-08-2007 12:50 PM
