2001 S500 Suspension problem - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 11-05-2009, 11:52 AM Thread Starter
snoopyrs1's Avatar
Date registered: Nov 2009
Vehicle: 2001 S500
Smile 2001 S500 Suspension problem
I have 2001 s500 with the airsuspension slamed to the ground. How is it posible to test the system without going broke in the process? and where are the pumps located so chk if they are in working order.. Thanks in advance
snoopyrs1 is offline
post #2 of 4 (permalink) Old 11-05-2009, 02:32 PM
50$84sd's Avatar
Date registered: Oct 2009
Vehicle: 1965 220se w111 *******1984 300sd w126 *******1991 350sd w126
I say keep it slammed, unless it's not your style (LOL). Later.
50$84sd is offline
post #3 of 4 (permalink) Old 11-05-2009, 05:11 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
The airmatic pump goes bad all the time. it is located under the right front of the bumper. there is a large 40 amp fuse located in the fusebox near the right side of the firewall. replace the fuse, relay and pump. the front shocks also have problems with the tops of them leaking, but since the whole car is slammed start with the pump...
pump is roughly $250 or so...let me know if you need any other help
saleen1276 is offline
post #4 of 4 (permalink) Old 11-05-2009, 05:42 PM
Musikmann's Avatar
Quoted: 5 Post(s)
Might be a better question to ask on the W220 forum.
Musikmann is offline
    S500 REAR SUSPENSION HELP! benzotech2003 W140 S-Class 7 07-11-2009 10:44 PM
    2001 S500 Climate Control problem ssimard W220 S-Class 5 07-28-2008 01:17 PM
    Climate Control problem 2001 S500 ssimard General Mercedes-Benz 0 07-21-2008 07:09 AM
    2001 S500 Phone problem aazapf W220 S-Class 6 07-20-2006 11:24 AM
    2001 S500 Airmatic Problem 04yfz W220 S-Class 13 06-22-2005 05:06 AM
