Problem with SLK230: Brakes, spring, and leak from drive shaft seal - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-05-2009, 09:16 AM Thread Starter
Date registered: May 2009
Vehicle: Mercedes SLK 230 Kompressor 1999
Send a message via MSN to thanos78
Cool Problem with SLK230: Brakes, spring, and leak from drive shaft seal
I am new in the forum. I have an SLK230 model 2000 (57.000miles) and I thought my brakes were weak. I took it to the dealer (paid £50) for a health check and they found several things:
-Front brake discs and pads need replacement: £469
-Brake fluid replacement: £93
-Spring front near side broken (donno how!?): £266
-Leak from left drive shaft seal: £565
-Down pipe bolts corroaded also manifold security bolt: £ 1000
So the sum would be more than £2000 !!!!
I am really shocked about the bill. I would like to ask whether these are real figures or dealer figures and how much it will cost if I take it to a local garage or Kwik fit.
thanos78 is offline
post #2 of 2 (permalink) Old 11-06-2009, 08:01 AM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
Those are definitely dealer figures. I could see you needing the brakes and brake fluid, but the springs and downpipe bolts sound like a BS thing to me.
As for the seal, do you see anything leaking from the car?
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
    Problem with SLK230: Brakes, spring, and leak from drive shaft seal thanos78 General Mercedes-Benz 1 11-06-2009 11:08 PM
    Output shaft seal KDools W123 E,CE,D,CD,TD,TE Class 6 03-14-2009 04:41 PM
    Tranny input shaft seal leak?? Need seasoned opinions... CBFintheODD W210 E-Class 4 11-03-2008 11:29 AM
    Rear Drive Shaft - Pinoin Seal MarJa W163 M-Class 4 04-05-2006 02:01 PM
