Problem with SLK230: Brakes, spring, and leak from drive shaft seal - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-05-2009, 08:35 AM Thread Starter
Date registered: May 2009
Vehicle: Mercedes SLK 230 Kompressor 1999
Send a message via MSN to thanos78
Cool Problem with SLK230: Brakes, spring, and leak from drive shaft seal
Hello,
I am new in the forum. I have an SLK230 model 2000 (57.000miles) and I thought my brakes were weak. I took it to the dealer (paid £50) for a health check and they found several things:
-Front brake discs and pads need replacement: £469
-Brake fluid replacement: £93
-Spring front near side broken (donno how!?): £266
-Leak from left drive shaft seal: £565
-Down pipe bolts corroaded also manifold security bolt: £ 1000
So the sum would be more than £2000 !!!!
I am really shocked about the bill. I would like to ask whether these are real figures or dealer figures and how much it will cost if I take it to a local garage or Kwik fit.
Cheers!
Thanos
thanos78 is offline
post #2 of 2 (permalink) Old 11-06-2009, 11:08 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 6 Post(s)
leapyfish is offline
AC Compressor Shaft Seal Leaks woowoo W210 E-Class 3 04-17-2009 07:05 AM
Output shaft seal KDools W123 E,CE,D,CD,TD,TE Class 6 03-14-2009 04:41 PM
Tranny input shaft seal leak?? Need seasoned opinions... CBFintheODD W210 E-Class 4 11-03-2008 11:29 AM
Rear Drive Shaft - Pinoin Seal MarJa W163 M-Class 4 04-05-2006 02:01 PM
