How do I open trunk on '01 S500 with battery disconnected? - Mercedes-Benz Forum
post #1 of 11 (permalink) Old 11-04-2009, 09:12 PM Thread Starter
Date registered: Jul 2008
Vehicle: 1998 E320
Help- I disconnected the battery to do body work on the doors (rust) assuming there was a mechanical method (key) to re-open trunk lid like on my E320. NOT! Tried the push button in the license plate opening with the key to no avail. Whats the trick?
kldburke is offline
post #2 of 11 (permalink) Old 11-04-2009, 09:17 PM
eric242340's Avatar
Quoted: 296 Post(s)
In the engine compartment there is a pos and neg terminal, connect a battery to these with jumper leads.
ERIC.
eric242340 is offline
post #3 of 11 (permalink) Old 11-04-2009, 10:54 PM
Diesel Benz's Avatar
Quoted: 35 Post(s)
The trunk can be opened with the mechanical key, assuming your lock works.
"To unlock and open the trunk lid, turn mechanical key to position1, hold and push to open."
Name:	W220 trunk lock.jpg
Diesel Benz is offline
post #4 of 11 (permalink) Old 11-05-2009, 05:51 AM Thread Starter
Vehicle: 1998 E320
looked for pos terminal- dont see it
Thank you for the quick reply-cannot find it- obviously it would be protected but spent hour looking-do I need new glasses?
kldburke is offline
post #5 of 11 (permalink) Old 11-05-2009, 05:54 AM Thread Starter
Vehicle: 1998 E320
That doesnt work unfortunately
the lid has apparently been replced at some point- gave up on that the first night. thank you for responding
kldburke is offline
post #6 of 11 (permalink) Old 11-05-2009, 06:02 AM
eric242340's Avatar
Quoted: 296 Post(s)
Hey, Diesel Benz, pics of the Positive and neg connectors? I am at home now and no access to WIS.
ERIC.
post #7 of 11 (permalink) Old 11-05-2009, 07:17 AM
Quoted: 35 Post(s)
So this was a W220, I cannot find jump start poles from the engine bay, the W210 would have had those. Of course I may have missed the info.
post #8 of 11 (permalink) Old 11-06-2009, 05:32 AM Thread Starter
Vehicle: 1998 E320
Can you tell me where the main pos cable terminates in the vehicle? Is it at the starter or some other point?My idea would be to disconnect the main power cable at that point and connect a power source there to energize the system.
kldburke is offline
post #9 of 11 (permalink) Old 11-06-2009, 05:53 AM
eric242340's Avatar
Quoted: 296 Post(s)
The power point connector is about 3/4 of an inch tall, nut and as you face the engine the point is rear left and usually has a red plastic cover with a + on it, but if you cannot find this, then go under the car, rear of engine, passengers side and follow the starter lead from the starter to the fire wall and you can connect pos to that point.
ERIC.
post #10 of 11 (permalink) Old 11-06-2009, 06:10 AM Thread Starter
Vehicle: 1998 E320
Cool- Thank you for your help. I am definitely retrofitting this one with jump posts after I buy it!
kldburke is offline
    HELP! S500 TRUNK WONT OPEN! MRS500901 W220 S-Class 17 03-09-2016 11:45 AM
    S500 trunk won't open andy52 W220 S-Class 31 02-15-2016 04:32 AM
    Battery dead - how to open trunk? lnguyenh W140 S-Class 6 04-23-2012 02:15 AM
    battery disconnected and trunk won't open!! 79silverwraith W140 S-Class 37 11-19-2010 12:16 PM
    Trunk won't open (battery drained) Lorinser925 W140 S-Class 16 12-18-2008 03:28 PM
