ml 20 inch wheels fitment - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 11-04-2009, 03:38 PM Thread Starter
Date registered: Mar 2008
i have a 2000 ml 320 looking at new wheels that are aftermarket
they are 112 x 20 x 8.5 have a offset et 38
will these work ?
i know my stocks were a 16 inch 8j offset 62
thanks for your help.......
manifesto is offline
post #2 of 5 (permalink) Old 11-05-2009, 06:12 AM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
The offset may not work, I think they will rub because the rim is wider then the standard rim and has the same offset.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
post #3 of 5 (permalink) Old 11-05-2009, 06:18 AM
vito-sam's Avatar
Date registered: Oct 2009
Vehicle: 2003 Vito Traveliner 108CDI
those wheels will stick out 24mm more as the offset is 24mm less.
vito-sam is offline
post #4 of 5 (permalink) Old 11-06-2009, 06:04 AM Thread Starter
wheel fitment
so if they stick out 24 mm then they should work, correct? i dont mind if they stick out a little more makes it a bit more aggresive looking maybe
post #5 of 5 (permalink) Old 11-06-2009, 07:47 AM
Kajtek1's Avatar
Quoted: 1068 Post(s)
Sticking out might be good to somebody's taste, but than it might interfere with fender clearance. ML has tricky suspension. Most of the time the suspension don't sag enough to close the gap between top of the tire and fender, but under heavy load on road bumps it will.
I had the situation on ML55 where even with correct sizing -different brand tire was 10mm wider at the crown than OEM tire. Drove with it for 2 years just fine, till I hooked up a trailer with heavy tongue weight and than rubbing happen.
Kajtek1 is online now
    AMG 18 inch Monobloc II tire fitment JR_Rider W126 S,SE,SEC,SEL,SD,SDL Class 13 09-01-2009 03:11 PM
    wheels fitment 04BrabusCLK C209/A209 CLK-Class 0 05-26-2006 11:52 AM
    Wheels fitment Help!!! tabolau W211 E-Class 1 10-25-2005 11:19 AM
    d93 17 inch lorinser fitment zdmcman The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 09-11-2005 10:05 PM
    For Sale: 2002 Lexus LS 430 16 inch tires and Brand new 2002 LS430 16 inch Chrome wheels Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 02-20-2002 07:24 PM
