faulty gauge cluster - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 11-02-2009, 03:28 PM Thread Starter
Date registered: Aug 2009
Hey I was wondering if any one has had this problem. i have a 97 c280 and my gauges work about 1 out of every 5 times i use the car. its not like the sticky gauges the needles dont have any little posts to sit on and they never pop on while your driving. when you start the car they either work or they dont. thanks!
mtscorvette is offline
post #2 of 2 (permalink) Old 11-03-2009, 04:16 PM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
Sounds like you have a short in the wiring. I would pull the dash and the gauge cluster to see if there are any loose connections and also make sure that the wiring is still in good shape.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
    Do You Have A Faulty Fuel Gauge? Yazovets! W164 M-Class 14 03-21-2009 12:58 PM
    Faulty fuel gauge, or not? MBeige W124 E,CE,D,TD Class 5 04-30-2007 06:18 PM
    Problems fitting 500 fuel gauge-oil pres'-water temp gauge cluster to 560 clocks mutley666 W126 S,SE,SEC,SEL,SD,SDL Class 2 10-10-2005 09:03 AM
    Faulty outside temp gauge Iwan W203 C-Class 2 11-01-2003 10:07 PM
    Faulty gauge cluster in 83 300D SHIFT_diesel W123 E,CE,D,CD,TD,TE Class 4 09-26-2003 09:50 AM
