Timing Chain - Page 2 - Mercedes-Benz Forum
post #11 of 19 (permalink) Old 11-03-2009, 08:48 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Originally Posted by deanyel View Post
The formula for a 119 motor chain problem seems to be slightly stretched chain, marginal tensioner, neither of which is a problem until the upper chain guide breaks, usually bank 1. The guides are made out of nylon, subject to heat cycle degradation - wise to replace them somewhere in the 100-150k / 10-15 year range, especially if you drive hard. It's not a very expensive job.
Thanks for explaining this in detail. Unfortunately doesn't look good for the OP, let's hope his car is an exception.
Diesel Benz is offline
post #12 of 19 (permalink) Old 11-03-2009, 05:20 PM Thread Starter
Date registered: Oct 2009
Well it is confirmed, the timing chain broke and the engine is worthless! I am not sure what I am going to do. To put a new motor in is going to be over $5k with only a 30 day warranty. To have the engine rebuilt with a 3 year warranty is around $6,500. The sad thing is the rest of the car is in great shape. Any advice.........
ColinE-420 is offline
post #13 of 19 (permalink) Old 11-03-2009, 06:48 PM
Kajtek1's Avatar
Quoted: 1197 Post(s)
Those cars generate good money parting out.
One owner of perfectly good ML55 had it parted out to get the price he couldn't get selling it as a whole.
Than sounds that investing 5 grands to get newer engine might still make lot of sense.
You will not get you money back if you sell the car next year, but statistically you can enjoy next 10 years of good ride.
The only problem is that you just proved to be exception to the statistics, but hey, there always are exceptions.
Kajtek1 is offline
post #14 of 19 (permalink) Old 11-03-2009, 07:25 PM
Date registered: Jul 2004
Quoted: 306 Post(s)
What was going on there? I've never heard of a double row timing chain just breaking, especially at such low miles. You should be able to get a replacement engine for a lot less than $5k, a whole lot less.
deanyel is offline
post #15 of 19 (permalink) Old 11-04-2009, 07:36 AM Thread Starter
The $5k is everything in (labour, new timing chain, oil change etc) The motor itself is around $2k. Now to convince the better half...........
post #16 of 19 (permalink) Old 11-04-2009, 11:01 AM
Quoted: 306 Post(s)
Still way too high - you need to get that down considerably to have any hope of an economically viable project.
deanyel is offline
post #17 of 19 (permalink) Old 11-06-2009, 09:56 AM Thread Starter
I located an engine for $1,400 with 188,000 km on it (how I can verify the mileage, I have no idea) but again, it is the labour that takes the cost up over $3,500. My feeling is to part the car out.
Thanks everyone for your advice!
post #18 of 19 (permalink) Old 11-07-2009, 09:56 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Originally Posted by Kajtek1 View Post
When the crankshaft is not turning that is not a good thing.
I'm sure his crankshaft is turning just peachy.
flyboyike is offline
post #19 of 19 (permalink) Old 11-07-2009, 09:58 AM
flyboyike's Avatar
Quoted: 69 Post(s)
Well, I agree that it does seem like a somewhat premature failure, but we don't know the maintenance history of this particular engine, so...
As for five grand for an engine, that seems if anything a little low.
    Timing Chain Master Link - will Iwis work on the BECK ARNLEY CHAIN?? xxxbradxxx W123 E,CE,D,CD,TD,TE Class 8 10-17-2009 06:53 AM
    Feeding in timing chain, attaching to old chain petecooke W123 E,CE,D,CD,TD,TE Class 4 09-18-2009 11:36 AM
    IWIS timing chain compared to JWIS timing chain. ArkRoyal W126 S,SE,SEC,SEL,SD,SDL Class 5 07-01-2008 08:22 PM
    Timing Chain or Timing Belt on 230 Kompressor ? Bal C208/A208 CLK-Class 0 11-21-2005 02:08 PM
    Timing chain replacement/timing issue 1990 420SEL supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-09-2003 03:03 PM
