1998 ml320 runs great and stalls - Mercedes-Benz Forum
post #1 of 9 (permalink) Old 11-01-2009, 07:53 PM Thread Starter
Date registered: Nov 2009
Vehicle: 1998 Ml320 V6 3.2L
I have a 1998 Merecedes Benz ML320...car starts and runs great for about an hour then just stalls...suv does it while parked at idle and while driving...after about a half an hour suv starts right up again and runs fine untill it just stalls again...i have no trouble codes and have just replaced the fuel filter and cps sensor after the problem started...any thoughts?
anthonym13 is offline
post #2 of 9 (permalink) Old 11-01-2009, 11:42 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Where did you source your parts?
Which CPS did you change? The cam sensor on the front or the crank sensor in the rear?
Check Codes is offline
post #3 of 9 (permalink) Old 11-02-2009, 08:53 AM
Kajtek1's Avatar
Quoted: 1250 Post(s)
The fuel pump connectors on those trucks are weak point as well.
Check the fuel pressure on the rail next time it stall.
Kajtek1 is offline
post #4 of 9 (permalink) Old 11-02-2009, 10:55 AM Thread Starter
Orded all parts from autohausaz...and replaced cps on rear of engine...was unaware of one on the front
post #5 of 9 (permalink) Old 11-05-2009, 10:03 AM
JaredMBClinic's Avatar
Date registered: Sep 2009
Vehicle: 1998 C240
The connectors on the fuel pumps burn up sometimes.
JaredMBClinic is offline
post #6 of 9 (permalink) Old 11-26-2012, 08:52 AM
Date registered: Nov 2012
Vehicle: 1998 ML320
Solution
My ML320 has the same exact issues. If you do not mind me asking what did you do to resolve the stall and rest problem? You listed two parts and a third one you were going to try. Is this the path you used to resolve your issue.
Thanks
nhml320 is offline
post #7 of 9 (permalink) Old 11-26-2012, 12:19 PM
Date registered: Jul 2005
Quoted: 1088 Post(s)
When it won't start see if the tach moves up to about 150 RPM. If it does not I would get the crankshaft position sensor. Especially if it has to cool down before it will restart.
Make sure to only get the Bosch made sensor.
Noodles is offline
post #8 of 9 (permalink) Old 11-26-2012, 12:52 PM Thread Starter
The problem ended up being the cam position sensor on the rear of the engine. When the truck heated up to operating temp it would fail. I replaced it with a new one I got from autohausaz.com. And it's ran great ever since.
post #9 of 9 (permalink) Old 11-26-2012, 12:55 PM Thread Starter
I'm sorry I mean the crank position sensor on the rear of the engine.
    1998 Ml320 long crank, fuel pump not priming, new CPS , runs fine once started. 4matichell W163 M-Class 8 08-26-2012 05:09 PM
    1998 E280 stalls - but runs fine apart from that? dj_coleman General Mercedes-Benz 4 07-17-2008 09:11 AM
    1994 E420 problems, stalls and runs real rough RudyH13 W124 E,CE,D,TD Class 1 04-02-2008 07:21 PM
    FS 1993 E300 Runs Great Looks Great, WI SuspectZero For Sale/Wanted/Trade/Giveaway 3 07-23-2007 09:28 AM
    300SE stalls and dies, then starts right up and runs fine??? andrew6981 W126 S,SE,SEC,SEL,SD,SDL Class 3 12-03-2004 01:20 PM
