Adjusting and Cleaning Throttle - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-31-2009, 02:49 PM Thread Starter
mrc280's Avatar
Date registered: Oct 2009
Vehicle: 1997 c280
an the Throttle on a 1997 c280 be Adjusting and Cleaned,if so how any pic's would help,i had a problem with the starting i took the wire to the switch off and the car started up do that mean i have a bad Throttle actuator or bad Throttle Control Unit
mrc280 is offline
post #2 of 4 (permalink) Old 11-03-2009, 04:20 PM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 23 Post(s)
All you need to do to clean the throttle body is to take the intake hose and spray the butterfly with some throttle body cleaner. I do believe that the 97 c280 has a electronic throttle body.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
post #3 of 4 (permalink) Old 11-03-2009, 05:10 PM Thread Starter
mrc280's Avatar
Vehicle: 1997 c280
did that took it off cleaned it real good both sides, took off the Throttle Position SENOR and the car do that same as with it on,is it any wat to check it
mrc280 is offline
post #4 of 4 (permalink) Old 11-03-2009, 06:28 PM
Date registered: Jul 2004
Quoted: 337 Post(s)
No comprende - what's a SENOR? You need to check the fault codes - both OBDII and the 38 pin connector.
deanyel is online now
Adjusting and Cleaning Throttle mrc280 General Mercedes-Benz 0 10-30-2009 05:13 PM
adjusting throttle travel... mountainredneck W123 E,CE,D,CD,TD,TE Class 9 04-02-2009 02:37 PM
Adjusting gas pedal (throttle) Kingorcus W126 S,SE,SEC,SEL,SD,SDL Class 1 03-06-2006 01:01 PM
adjusting throttle CI300CE W140 S-Class 0 09-26-2004 02:26 PM
