2001 ML320 BAS/ESP, ETS,ABS, brake warning, check engine signs all on! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-30-2009, 01:48 PM Thread Starter
Date registered: Oct 2009
Cool 2001 ML320 BAS/ESP, ETS,ABS, brake warning, check engine signs all on!
Someone with same experience please help me!
My 2001 ML320 had check engine light for months which I ignored.
2 months and 2000 miles ago I had front brake pads and rotors replaced at a shop (OEM ones).
Since 1 month ago occasionally in the morning when it's chilly here in San Diego, BAS/ESP,ETS,ABS,Brake warning sign and red Brake sign illuminate all at once with beeping sound upon ignition or 5-10 seconds after ignition. Car shakes upon gear change. When I drive on, speedometer stays at 0, although tacometer works and the car feels like scratching on the ground with increased friction, as if I had not released the brake.
This is not happening when I start the car later in the day when it's warmer. The next morning it recurs.
As you might have noticed, I am a novice. Someone said it's brake switch. others said it's speed sensor. Stealership said ESP control unit, traction unit. They said ESP control unit is faulting and ESP control unit connector has corrosion, quote for replacement is $3319.
I know similar problems were posted here many, many times but wondering if someone had exactly same problem I have and can share how they handled it. Thanks!
CWLEE is offline
post #2 of 4 (permalink) Old 10-30-2009, 04:40 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Did the stealer hook it up to the Mercedes SDS system to arrive at this dianosis? If so, it's a pretty sure thing, although nothing is perfect.
The first thing I would do is check your battery. Not only is that inexpensive and easy to do, but there have been numerous complaints of this general nature (several warning lights on simultaneously) and a few times the problem was low voltage due to a bad battery.
The shaking on shifts and the scratching are probably something else, and I'm not a wizard when it comes to self repair either. The speedometer is a but quizzical but that might be due to an electrical issue too.
Musikmann is offline
post #3 of 4 (permalink) Old 10-30-2009, 10:45 PM Thread Starter
I am not sure if they hooked with SDS system but
The paper says I requested MPI World Class Inspection. Should I ask them if they did SDS inspection, you think?
It said " recommend new control unit and further advise" so I guess they just want to try this out and see if this fixes the problem? And it will cost me over $3000!
Thank you for the reply BTW.
Can anyone share any other thoughts?
CWLEE is offline
post #4 of 4 (permalink) Old 10-31-2009, 06:35 AM
Musikmann's Avatar
Quoted: 6 Post(s)
I don't know what MPI World Class means, but any competant dealer would have used the Star (SDS) system. It wouldn't hurt to ask them what they did. They might be just replacing parts, it's hard to tell. Also, find the correct ML-Class forum and ask your questions there too.
Back Again BAS/ETS ESP ABS Lights on...and check Engine vancevirgil W163 M-Class 7 12-16-2011 12:21 AM
BAS/ESP+ETS+ABS+Brake-Pads+Brake steffen.gutmann W163 M-Class 17 09-13-2009 10:32 AM
ML 430 - 2000 - I NEED HELP!My BAS/ESP, ETS(ABS) and (Check Engine) lights come on. T nhaile W163 M-Class 3 09-19-2006 08:20 PM
01 ML320 ABS/ETS/BAS-ESP Lights On hlai W163 M-Class 6 06-21-2006 05:45 AM
