84 380 SL - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-30-2009, 10:58 AM Thread Starter
Date registered: Oct 2009
Vehicle: 1984 380 SL
Send a message via Skype™ to sirknightrichard
84 380 SL
Ahoy from Dallas Tx
I'm sure there is already a thread on this, as it seems to be a very common problem, but my new old car (84 380SL) has idle problems. Mostly, rough idle and surge at idle. I think I need to check the idle speed relay, but have no clue WHERE it is located on this model.
Also, it had bad tappet noise on the passenger side, so we replaced all rocker arms (was told that the cam was OK) and now after about 500 miles the noise is coming back. Do you think it is the cam?
Finally, has anyone heard of a successful motor swap in this car, putting in an American motor that isn't so exotic?
Dick Brown
sirknightrichard is offline
post #2 of 4 (permalink) Old 10-30-2009, 11:28 AM
bandit96's Avatar
Date registered: Dec 2008
Vehicle: 1981 380SL - Lorinser bodykit w/16x7 LOs - AKA "Frau Blau"(Lady Blue)
Quoted: 35 Post(s)
Originally Posted by sirknightrichard View Post
Ahoy from Dallas Tx
Dick Brown
Welcome to the wonderful world of the 107.
You can check my thread "my 380SL project" as I have had to deal with the same issues. The engine has cam oiler tubes that run across the top of the cam bearings. I found that mine had some serious blockage that resulted in two of the rockers not getting enough lubrication and going bad. Thus resulting in that wonderful "diesel" sound. Even now when I start her up, it will be noisy for about 30 seconds or so, then it builds enough oil pressure to load the compensators.
Nothing really exotic about the 3.8, it's just a bit different and once you know what to look for it's fairly easily fixed.
Check your vacuum lines and valves for leaks. This is the most common cause of the idle issue. Mine is doing the same thing and I am going to be going through the systems here shortly.
Bandit
"If you don't know what you're looking for it's kind of hard to find it!"
CCTORONTO:
If it helps America through it's current crisis, I say go ahead! We can take it, after all we're Canadian!
Blame Canada!!
bandit96 is offline
post #3 of 4 (permalink) Old 10-30-2009, 03:08 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 6 Post(s)
leapyfish is offline
post #4 of 4 (permalink) Old 10-30-2009, 03:11 PM Thread Starter
Howdy Bandit..
When we replaced the rockers (all of em) on the passenger side, the mechanic noted that the oiler looked "new" and had likely been replaced. In any case, it was clean and functioning properly.
I don't think there is a vaccum leak, either, but I'll try to follow all the hoses and lines and look for a crack or break. I have not found one yet.
From reading threads on the internet (this forum and elsewhere) I tend to think the problem is the idle speed relay, or something in that circuit. I have noticed that the temp guage "jumps" at times (not consistently or frequently, just on occasion) and I am led to believe that the water temp. sensor plays a role in the idle speed relay circuit. However, disconnecting it doesn't seem to make any difference in the "surge" idle. It lopes at idle, but the slightest pressure on the accelerator smooths it out. It's like I need a good old fashioned "idle speed adjustment screw" to turn a few threads!
Later,
Dick
FS: 380 SL osdesierto For Sale/Wanted/Trade/Giveaway 3 03-27-2008 01:15 PM
Considering an 82 380 athensaaron R/C107 SL/SLC Class 7 01-02-2008 06:25 PM
380 SD?? merouby W126 S,SE,SEC,SEL,SD,SDL Class 2 01-27-2004 07:34 PM
380 SE Guest (MBNZ) General Mercedes-Benz 3 07-24-2002 06:09 AM
380 SE Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 5 07-06-2002 11:29 AM
