tranny shift help - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-28-2009, 02:57 PM Thread Starter
Date registered: Sep 2009
tranny shift help
sorry to bug you i was wanting your help . i have an 300sd its an 84.im not 100 sure ive got my throttle set right .i had my guage hooked up and checked it while it was in park and checked it by pulling the throttle rod under the hood it started out at 13 to zero at full throttle .with everything hooked up it wasnt going into 4th gear . i unhooked the vaccuum line going to the tranny and took it for a drive it shifted into 4th gear . i went and got some extra vac line and put me a t in my line fromb the vac line to the tranny and drove it . it wouldnt shift into 4th but it went from 13 to only 5 bars not zero what it should have at full throttle . transmission shifts without the vac line .what do you think it is my throttle out of adjustment my bowden cable or need to adjust my vaccuum pressure
brain2 is offline
post #2 of 2 (permalink) Old 10-28-2009, 04:22 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Yours are some pretty specific questions and this forum is called General Mercedes-Benz. You have a W123 and there is a forum devoted to that chassis. Scroll down to the sedans section and you will see a better place to ask the other actual owners. Good luck and welcome to the forum.
Musikmann is offline
Help! My Tranny will not shift out of 1st gear... Low Key W163 M-Class 8 09-11-2008 09:36 AM
Tranny shift BigNBeefyCLK320 C208/A208 CLK-Class 0 05-30-2008 07:20 PM
Tranny wont shift cisaacson W210 E-Class 9 02-18-2007 04:45 PM
Tranny Hesitate To Shift When Cold wstasw C208/A208 CLK-Class 8 01-26-2007 09:55 PM
Does your upgraded 32 tranny shift slow? Shane R170 SLK-Class 4 07-18-2003 08:34 AM
