Help! Need to remove scratches from center console simulated wood cover - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-26-2009, 07:06 PM Thread Starter
Date registered: Sep 2009
Vehicle: 2006 E350 4MATIC
Post Help! Need to remove scratches from center console simulated wood cover
Hi,
I have a 2006 E350 sedan (Minnesota.) My 2 yr old daughter just scratched the finish on the simulated wood center console cover (the sliding cover over the cup holders.)
The scratches are only in the finish (i.e., the plastic laminate covering.)
Searching the internet I found the following products in a cadillac forum - the interior in CTS' is simulated wood, but with a black lacquer finish. Althought it should work the same for my MB (honey/walnut finish?), but just checking if anyone has any advice.
NOVUS scratch removers
PlastiX by Maguairs
Blue magic Plastic & Plexiglass cleaner and scratch remover
Thanks in advance.
AQ
AQMBE350 is offline
post #2 of 3 (permalink) Old 10-26-2009, 08:23 PM
Date registered: Aug 2008
Vehicle: 2005 CLK320, 1989 560SL, 2006 SLK350
I didn't think Mercedes used fake wood in any car. I believe it is real wood that is heavily clearcoated. I could be wrong, but before I tried anything I'd talk to a detalier that may have some experience with the car.
2005 Mercedes-Benz CLK 320; 1989 Mercedes-Benz 560SL; 2006 SLK350; 2006 ML350
Scottsdale, AZ
MX-5.0 is offline
post #3 of 3 (permalink) Old 10-27-2009, 10:19 AM
Musikmann's Avatar
Quoted: 6 Post(s)
Agreeing about the real wood/clearcoated. Once scratched these are not easy to fix well. Search around on the Deatailing forum and you should find a couple threads on this.
Musikmann is offline
    How to remove center console wood slonar21 C215 CL-Class 5 08-07-2009 03:28 PM
    2000 S430 - Center Console Wood Storage Cover farwell_race W220 S-Class 2 01-08-2009 01:00 PM
    Tips to remove wood center console/door panel??? draglink W124 E,CE,D,TD Class 8 10-24-2008 12:20 AM
    Remove Center Console Wood mattwestm W163 M-Class 0 07-20-2007 11:49 AM
    How Do You Remove Center Console Wood? Morpheus W126 S,SE,SEC,SEL,SD,SDL Class 13 01-12-2006 04:55 PM
