can you pull the OBD-II Codes if the engain light is not no - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-26-2009, 01:16 PM Thread Starter
mrc280's Avatar
Date registered: Oct 2009
Vehicle: 1997 c280
I was told by the local advance auto parts store that you can't pull the OBD-II Codes if the engine light is not on is that right
mrc280 is offline
post #2 of 5 (permalink) Old 10-26-2009, 01:47 PM
e-420's Avatar
Date registered: Sep 2008
Vehicle: 1997 E-420 (150K miles), 1997 SL500, (90K miles) 2015 GMC Sierra Denali 2500HD CC/SB/4x4 Duramax
Quoted: 386 Post(s)
If you are refering to the "check engine light" or similar, not entirely true. If the light is not on, it means no codes have been set that require activating the "check engine light". However, many vehicles do set "pending codes" or codes that do NOT activate the check engine light. If these are set most, if not all, OBD-II readers should be able to read pending or other codes.
Examples of a "pending code" may be engine misfire detected, but not long enough to set a code.
Examples of codes that don't set the "Check engine light" are "EGR malfunction" on my 04 Non- California diesel truck. The code will get set and can be read, however for 49 state vehicles, it won't trigger the "check engine light"
If you have a conditon that sets the "check engine light" and then goes away, he is likely correct in that you may not be able to read the code that was set in the first place.
--------His------------Hers-------
97 SL500 Imperial Red
/Parchment Leather/Black Top
Chromed OEM wheels, Akebono's, H1+90 fog, Burlwood/Leather shift knob, Rostra Lumbar support, Check seat heaters, Bilstein's, Parrot Bluetooth, GG Bailey Custom cargo mat, GG Bailey trunk mat, Real Burlwood Instrument Cluster w Chrome rings, Burlwood & Chrome shift surround, Euro headlights with Osram 70W/65W H-4's, clear corners, Silverstar corner lamps, Euro Trunk mount Warning triangle, SL600 Burlwood armrest trim & Burlwood cupholder sliding cover, Kahtec flashing third brake light (CHMSL)
97 E420 Royal Indigo/Grey Leather
Raintracker wiper, Rostra Lumbar support, Parrott Bluetooth, 17" chrome AMG replica wheels, Bilstein's, Akebono's, smoked marker lights, Osram 65W H7's, H1+90 fog, Rear Seat Child restraint Tether, Burlwood/Leather shift knob, OEM Mudflaps, DRL's, Becker Aux input
e-420 is offline
post #3 of 5 (permalink) Old 10-26-2009, 03:22 PM Thread Starter
mrc280's Avatar
Vehicle: 1997 c280
i have a 1997 c280 "check engine light in not on, but my car cranks but wont started, and dont wont to buy a OBD-II readers if there no codes to read,you say that there could be code that don't set the "Check engine light" so i should get then
mrc280 is offline
post #4 of 5 (permalink) Old 10-26-2009, 04:24 PM
Kajtek1's Avatar
Quoted: 1197 Post(s)
CEL indicate problem with engine emission and to my knowledge can be only set when the engine is running.
If your engine will not start, this is mostly due the fuel delivery problem, or bad CPS.
None of those triggers a code, than not having a scanner you are not sure.
Since the scanners are way cheaper than dealer's charge for one tome scanning, this is no brainer to me if i should own one.
Kajtek1 is online now
post #5 of 5 (permalink) Old 10-26-2009, 06:02 PM Thread Starter
mrc280's Avatar
Vehicle: 1997 c280
thanks
mrc280 is offline
    OBD..Can any OBD scanner clear all codes for a 2000MB? ike00 W163 M-Class 8 09-16-2008 08:28 AM
    Help with 4 different OBD codes bboyer32 General Mercedes-Benz 3 07-22-2008 04:19 AM
    How do you pull codes for the check engine light on 94 e420? porshapower W124 E,CE,D,TD Class 2 09-15-2006 11:15 AM
    OBD Codes? gillejb C208/A208 CLK-Class 10 09-24-2005 09:57 PM
    OBD CODES Merc600sec General Mercedes-Benz 2 02-19-2005 02:34 PM
