Tire clearance puzzle - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-24-2009, 12:07 PM Thread Starter
Date registered: Nov 2008
Exclamation Tire clearance puzzle
Greetings Gents,
If the board can assist with this one, it would be a great help. I have a 2000 E430 base model with very unusual tire wear that makes me suspect something is interfering with the inside edge of the front tires. While checking for interference with the tire I noticed that there is very little space between the upper control arm bolt/nut and the inside edge of the tire...about a finger tip gap, 10mm (see picture). The clearance is quite minimal.
I checked the same gap on an E430 4matic and the gap was about 30 - 35 mm.
I'm tring to figure out if my configuration is correct. The two components that determine the gap are the steering knuckle and upper control arm. Therefore, can anyone tell me if the 2000 E430 base vs. 4matic models share the same steering knuckle and upper control arm part numbers or do they differ? Is there an explanation for the difference in clearances?
Much appreciated, Matt
Name:	E430 tire clearance.jpg
mditka85 is offline
post #2 of 4 (permalink) Old 10-24-2009, 12:54 PM
Date registered: Feb 2005
Vehicle: '03 CL500,& '07 GL450
Question
Correct wheel width, offset,and tire width for your vehicle?
'03 CL500,'07 GL450
reddog is offline
post #3 of 4 (permalink) Old 10-24-2009, 02:02 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Did you measure that clearance with the wheel straight or turned? It gets smaller at full lock. 10mm at full lock would be fine.
I'm guessing you don't have OEM wheels and tires for the model on your car.
Two additional things: consider getting out of the general forum and instead hang out in the 210 forum, which is chock full of specific information about your car. Second, please click user cp and add vehicle and location info to your profile.
Check Codes is offline
post #4 of 4 (permalink) Old 10-25-2009, 07:47 PM Thread Starter
Guys,
Stock 17" wheels with stock 235/45/17 tires. The gap is fairly consistent from straight forward vs steering lock but the 10mm refers to straight forward.
Does anyone know if the E430 base and 4matic share the same suspension components? specifically the steering knuckle and upper control arm?
Thanks, Matt
mditka85 is offline
    Front Tire Clearance / Airmatic bmurphywa W220 S-Class 2 02-20-2009 07:33 AM
    How much tire clearance do I actually have??? Gorman W211 E-Class 4 11-17-2008 06:52 PM
    will 285/30/19 tire fit a 19x8.5 wheel? Will it fit? Fender clearance problems?? spine911 W210 E-Class 1 11-03-2004 04:46 PM
    Tire Clearance Heavyd The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 07-14-2003 12:28 PM
    Tire Clearance Heavyd W210 E-Class 4 07-01-2003 05:41 PM
