Hard to start with less than half tank 1987 300SDL - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-22-2009, 07:17 PM Thread Starter
Date registered: Jan 2009
Vehicle: 1970 280SEL, 1986 420SEL, 2002 C280
Post Hard to start with less than half tank 1987 300SDL
Hey all,
I have a 1987 300SDL. 150,000 miles. Just did alot of work and this problem still exists. Replaced all filters, replaced the fuel hoses between the injectors fixed a leaking coolant hose etc etc. This one existed before I started the repairs. I dont know what is in the fuel tank that could make it VERY VERY hard to start at anything less than 1/2 a tank. Every night when it is less than 1/2 in the morning it takes a good 4 minutes of cranking to start. But anything over 1/2 tank it starts first try. Any help would be appreciated I hit the road at 3:00AM and am starting to notice neighbors lights coming on and them peeking through the window.
alexsystems is offline
post #2 of 3 (permalink) Old 10-22-2009, 08:20 PM
Kajtek1's Avatar
Quoted: 1059 Post(s)
General rule is that the only thing that makes troubles in diesel is the air entering the fuel lines .
Check all the connectors and if you don't have clear tubing on fuel lines, you might want to install one to observe possible air bubbles.
On older car dirt on fuel tank strainer is quite possible as well.
Kajtek1 is online now
post #3 of 3 (permalink) Old 10-22-2009, 08:52 PM
Date registered: Sep 2009
Vehicle: 2000 Mercedes ML55 AMG
im still pretty new to MB but with VW there is a check valve in the fuel tank. If it fails, the fuel pressure is slowly lost. So if you were to drive it all day, then park it for the night and start it up in the morning, there would be no pressure in the lines and it would take some time for the fuel pump to again pressurize the lines. But like I said.. I'm still new to MB.
Brettriehl101 is offline
    1987 300e hard start.. tntedboi W124 E,CE,D,TD Class 4 10-24-2009 04:06 PM
    Hard start: 1987 300E zaphiri W124 E,CE,D,TD Class 5 10-17-2009 07:21 PM
    1987 260E Hard Start California260E W124 E,CE,D,TD Class 0 03-04-2009 05:54 PM
    1987 300E hard to start at running temp DADARKPRINCE W124 E,CE,D,TD Class 3 10-10-2006 02:49 PM
    1987 W124 300E hard to start hot or cold Any ideas. rcs hawaii W124 E,CE,D,TD Class 1 12-15-2004 07:31 AM
