'02 E320 WAGON Shock repair question - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-22-2009, 05:37 AM Thread Starter
Date registered: Jan 2006
Send a message via AIM to clinning
Recently, w/ 110k miles, I took my car in for repair to the shocks (it was riding rough). Front shocks were repaired fine, but shop disassembled rear PNEUMATIC shocks w/o knowing that the were pneumatic (i.e. Load-leveling) ... I didn't know either.
Anyway, they had ordered the wrong parts, so they put it back together with the old ones (continuing to tell me that I still needed to have the $1,000 repair ... which I believe is untrue).
As a result of improper reassembly (I believe), I had an immediate rear emergency brake shoe failure, resulting in additional damage to the car.
Can anyone confirm/dispute whether dis-assembly/re-assembly of the rear Pneumatic shocks in a '02 MB Wagon can affect the emergency brake shoes?
Shop denies all responsibility....
clinning is offline
post #2 of 2 (permalink) Old 10-22-2009, 07:41 AM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T current 2014 lexus LS460
You are paying for incompetant mechanical service. The fronts can be done by a high school student, the rears are hydraulic struts that are fed thru a valve and are in line to hydraulic spheres (accumulators). The accumulators have adiaphram and the hydraulic oil and nitrogen are seperated. As the spheres fail the spheres fail and the gas leaks out, oil cant be compressed any more and therefore the rough ride. The hydraulic struts (shock look alike) can fail, they usually leak.
The only way the brakes can be screwed up is, by doing something to either the cables, running in a lug bolt without the wheel, or something else, but not the strut.
They, dont know a thing, by the way the power steering pump also serves both systems and MB oil is required. Sometimes it makes sense to use the dealer or a competent indy
Peter Guenther is offline
    99 E320 Shock Replacement Question kwhombre W210 E-Class 22 09-15-2012 07:43 PM
    '95 E320 Wagon Rear pass Door Pillar Cover Repair Graham W124 E,CE,D,TD Class 3 01-08-2009 01:15 AM
    '98 E320 Wagon question peru9800 General Mercedes-Benz 1 11-19-2008 09:40 AM
    E320 Wagon - rear hydropneumatic shock maintenence - please help! 2kjettaguy W124 E,CE,D,TD Class 3 05-14-2005 01:41 AM
    E320 Wagon Question- Deepak W163 M-Class 3 02-26-2002 05:50 AM
