1997 C280 Won't start-no codes - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-19-2009, 06:53 AM Thread Starter
mrc280's Avatar
Date registered: Oct 2009
Vehicle: 1997 c280
frist MB 1997 C280 Won't start-no codes,i got a used c280 from a friend,he broke the chip in key,he was thinking that the black part of key was just for the alarm systems,he did not know that is was a chip for the Ignition,so he took the Ignition apart trying to find the problem,he couldn't fix it so the car set up up for 9mths,so i got the car now,I install the Ignition back ,got a new key from the dealer,now car will crank but wont start ,sometime it starts run for 1 or 2 sec and dies,also when it did run it was real Rough,can only one help,i was told that gas is bad from setting up for 9mths ,I dont think so
mrc280 is offline
post #2 of 6 (permalink) Old 10-19-2009, 07:06 AM
Date registered: Jul 2004
Quoted: 337 Post(s)
No codes means what? No OBDII codes or ?
deanyel is online now
post #3 of 6 (permalink) Old 10-19-2009, 07:17 AM Thread Starter
mrc280's Avatar
Vehicle: 1997 c280
yes no OBDII codes
mrc280 is offline
post #4 of 6 (permalink) Old 10-19-2009, 03:01 PM
Vehicle: 08 CLK convertible, 2010 ML350 AWD
when installing a new EIS (ignition lock) assembly, it must be programmed into the car.. in other words.. its not just plug and play.. and its usually done with SDS (mb comp). was the programming of the ignition done?
kchoi919 is offline
post #5 of 6 (permalink) Old 10-19-2009, 04:49 PM Thread Starter
mrc280's Avatar
Vehicle: 1997 c280
the deal said the key was program, is that something new
mrc280 is offline
post #6 of 6 (permalink) Old 10-19-2009, 07:17 PM
keys comes programmed from mercedes when ordered... on your particular vehicle, the key shouldnt require additional programming.. however, your EIS or ignition does require programming after installation... perhaps you should take it to the dealer to see if they can program your ignition...
kchoi919 is offline
Fault Codes - 96 C280 jamesjedi W202 C-Class 6 08-13-2014 11:10 AM
Idle, MIsfiire, Codes on 1997 SL320 jporrata R129 SL-Class 3 03-08-2009 08:53 AM
C280 Sport - 1997 - Will not start - HELP! Big Dog General Mercedes-Benz 2 12-27-2007 03:38 PM
Difference in feel between the 1997 C280 and 1999 C280 SechsPackSound W202 C-Class 3 04-18-2006 05:48 PM
1997 SL 600 engine codes typhoontaz R129 SL-Class 0 11-21-2005 01:23 PM
