chain tensioner where is it? - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-18-2009, 03:14 PM Thread Starter
Date registered: Oct 2009
Vehicle: C200
Question chain tensioner where is it?
hi all, in the process of lifting the head off my 2003 c200 1.8 kompressor, having got to the stage where i need to remove the tensioner, now all i can see on the side of the chain cover is a 4cm diameter black rubber circle, is it behind this? its right behind where the alternator was which the nice haynes book told me to remove to get to the tensioner to unbolt it,sadly no photos to go with the instruction, its not the 111 engine(would of been a help if it was) but the 271 engine, if it is this black disc shaped seal how do i get into it?
podmo is offline
post #2 of 2 (permalink) Old 10-18-2009, 04:39 PM
Date registered: Feb 2008
Vehicle: 2004 W220 (S430) ; 2001 R129 (SL500) Sport
Location: Alabama Gulf Coast--formerly Charlottesville, VA
I'd go to the forum for your car and ask that question; you're more likely to find someone who has done that repair there.
It's obviously somewhere between the camshafts and the crank shaft. It's also likely behind the cover that hides the timing chain. But that's just intuition that anyone has.
Good luck.
"Don't pick a fight with an old man. If he is too old to fight, he'll just kill you."--John Steinbeck
DrJfrmLA is offline
    Is their a timing chain tensioner on our V8 ? fabbrisd1 W210 E50 AMG, E55 AMG 8 11-23-2010 05:00 PM
    Timing chain tensioner Jevile219 W201 190-Class 22 06-18-2007 05:36 PM
    chain tensioner ben merc W124 E,CE,D,TD Class 0 11-01-2005 01:43 PM
    Chain Tensioner Ben J Men R/C107 SL/SLC Class 1 10-11-2005 05:23 PM
    Changed chain tensioner, now the car wont start, help! Chain alignment not correct!? johan6504 W124 E,CE,D,TD Class 0 10-25-2003 06:25 AM
