Seat Adjustment for '02 CLK 320 - Mercedes-Benz Forum
post #1 of 16 (permalink) Old 10-17-2009, 07:40 PM Thread Starter
Date registered: May 2009
Vehicle: 2002 CLK 320
My passenger seat for an '02 CLK 320 is not functioning properly. The electrical recline and head-rest are working normally, but the front and back function are not (on the passenger seat only). Is there a simple resolution or should I take it in to the dealership for repair??
Narcisis is offline
post #2 of 16 (permalink) Old 10-20-2009, 07:04 AM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
First, just check to make sure the power seat connectors are all connected snuggly. They could have been knocked loose when vacuuming or something. Also, check all the fuses. You never know if that part of the seat is on another fuse.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
post #3 of 16 (permalink) Old 10-20-2009, 10:58 AM Thread Starter
Thanx for your response FCPGroton,
Although I am not too mechanically inclined, I did check the connections under the seat and found nothing unusual. As for a possible blown fuse, is there a (owner manual) fuse chart on line where I could reference to check the correct fuse?
Narcisis is offline
post #4 of 16 (permalink) Old 11-22-2009, 08:40 PM
I'm sure you've probably found out by now, but for future reference in the fuse box for your your seat controls is in the trunk under the spare tire cover on the top right. Under the cover is the locations of the fuses and their respective purpose. Your forward/back control *should* be #6, and the other functions is 7 and 8.
vocs75 is offline
post #5 of 16 (permalink) Old 11-23-2009, 04:40 AM
keyhole's Avatar
Date registered: Sep 2006
Vehicle: 2004 CLK 240 Coupe
Quoted: 373 Post(s)
You are 'almost right' - but the fuse distribution is a bit more complicated than your statement above.
From the WIS. Model 208.3 as of 1.6.99. Fusebox A, located in trunk. f1 to f9.
Front seat adjustment - (according to variants)
f6. 30A. either: front left seat fore/aft, backrest.
or: head restraint raise/lower, backrest, seat height at back.
f7. 30A. front left seat adjust. (bridged with f6)
front left seat fore/aft, seat height at front.
f8. 30A. either: front right seat fore/aft, backrest.
f9. 30A. front right seat adjust. (bridged with f8)
front right seat fore/aft, seat height at front.
That said, I reckon your problem is the passenger seat fore/aft motor has burned out. Look in the archives for more info on that fault.
keyhole is online now
post #6 of 16 (permalink) Old 11-23-2009, 09:21 AM
Thanks for the elaboration, I just wanted to note that checking the 'simple' stuff, like fuses, should always be the first step in troubleshooting. In looking up the problem myself I see a lot of people pointing out the motor or other more in depth causes before noting the seat motors are individually fused and often throws people off since they think that all of them would be one circuit, and on that premise ignore the checking of fuses.
vocs75 is offline
post #7 of 16 (permalink) Old 11-23-2009, 12:15 PM Thread Starter
Thanx to everyone that responded to my problem. The issue has been resolved and thankfully, it was a simple solution: replace the appropriate fuse. The answer was reflected in the suggestion above; it seems that I only checked the fuses under the hood and was not aware of the box located in the trunk. After my investigation there, I found the defective fuse, made the replacement, and now everything is fully opertional once again.
Thanx for everyone's response!!
Narcisis is offline
post #8 of 16 (permalink) Old 11-23-2009, 05:22 PM
keyhole's Avatar
Quoted: 373 Post(s)
Good result...
However you should now ask yourself, why did a 30A fuse blow? Was the seat movement blocked in some way? Fuses should not just blow for no reason...
post #9 of 16 (permalink) Old 03-04-2011, 07:43 AM
Date registered: Jan 2011
I'm a dumbass ... almost
I know this is an old thread ... but I still wanna add to it in case anyone ever comes across the same problem.
My CLK driver seat got stuck to where I had to drive with my knees in my face. Just like the other dude in this thread, my seat would tilt and recline, but no back/forth movement. I spent an hour messing with wires under the seat, disconnected the battery, and everything.
Gave up, figuring I'd have to enlist the help of a professional. Drove it for a week. Got so sick of it, figured I'd try some DIY. When I read OTHER threads, people were saying it couldn't be a fuse because some functions were still operational.
Guess what?
Fuse #6
I feel like an idiot, but am so very glad to be driving normal again.
Thanks to everyone who contributed ... particularly the guy who mentioned that they are all fused seperately.
Robby_Roastbeef is offline
post #10 of 16 (permalink) Old 05-15-2011, 05:38 PM
Date registered: May 2011
Vehicle: 63 190SL, 94 SL600, 01 CLK320, 01 S600, '89 300E, '93 500SEC
Hello:
The exact same has happened to me. There is a seperate fuse in the trunk for that specific function. You may need to examine all 10-12 fuses to find the right one, as I don't recall if it was labeled on the fuse chart. Remember, this is the TRUNK fuse panel, NOT the engine compartment or driver's side dash fuses. Thanks
TheGrandmaDee is offline
    CLK 320 REAR SEAT REMOVAL amarmotivala C208/A208 CLK-Class 1 10-11-2009 12:28 PM
    1999 CLK 320 cabriolet rear seat removal jhkanda C208/A208 CLK-Class 3 05-26-2009 03:31 PM
    Electric Seat not working - CLK 320...!!! Sunray General Mercedes-Benz 6 02-23-2009 03:22 PM
    CLK 320 seat motor Nor-Cal-CLK C208/A208 CLK-Class 2 04-26-2007 10:59 AM
    Octane of gas? Seat adjustment cover? Seat adjustment problem operagirl W126 S,SE,SEC,SEL,SD,SDL Class 13 08-23-2004 03:54 AM
