Seat Adjustment for '02 CLK 320 - Page 2 - Mercedes-Benz Forum
post #11 of 16 (permalink) Old 05-17-2012, 09:37 AM
Date registered: Dec 2010
bumping old post please help
Originally Posted by TheGrandmaDee View Post
Hello:
The exact same has happened to me. There is a seperate fuse in the trunk for that specific function. You may need to examine all 10-12 fuses to find the right one, as I don't recall if it was labeled on the fuse chart. Remember, this is the TRUNK fuse panel, NOT the engine compartment or driver's side dash fuses. Thanks
Your correct and thanks to this forum I found the fuses too. I wanted to note the fuse chart that covers all fuses in the Benz is located in the fuse panel next to the drivers seat folded all nice and neat. I can copy and post but its of cours e not a standard us paper.
My question my fuse was blown so I changed it however the seat moves up and back just not the full range of motion. I have checked and there is nothing jamming it up. if anyone is still watching this thread please help
DeBB is offline
post #12 of 16 (permalink) Old 05-17-2012, 05:26 PM
I fixed my seat! (crosses self) + (Knocks wood) there is a little pin at the end of each track on the back side. one came loose and was fouling the system. I could not see it until I took a thing a ma bob off and it was finally visible thru one of the holes. it took me at least 1.5 hours but thru patience and perseverance I was able to free it. tools I used, I am not joking. Shish ka bob (metal) it fit in the groove, hanger from cleaners wth a little turn on the end, allen wrench finally saved the day I hooked it on the clip thru the hole on the rail and moved the seat back while holding it. I dont need to do my Yoga for the day. If anyone needs I took pictures of the process. Just glad I didnt have to take the seat out. It did sound easy to do though
Cheers
DeBB is offline
post #13 of 16 (permalink) Old 05-21-2012, 08:40 AM
Date registered: May 2011
Vehicle: 63 190SL, 94 SL600, 01 CLK320, 01 S600, '89 300E, '93 500SEC
320CLK Seats are MULTI-FUSED. This means they one fuse will cover up-down while a seperate one forward and back. ALSO each seat has it's own fuses. If you get a repeat fuse that blows after only short usage, CHECK THE SEAT TRACKS THOROUGHLY. Even a piece of paper will blow the fuse. I had a toothpick in my track ruin my life until I really got in there with a couple of flash lights.
TheGrandmaDee is offline
post #14 of 16 (permalink) Old 06-16-2012, 03:52 AM
OAKESY 320's Avatar
Date registered: Apr 2012
Vehicle: clk320 conv
glad for the help, i've been driving my car for 2 weeks with my knee's around my kneck
OAKESY 320 is offline
post #15 of 16 (permalink) Old 01-27-2015, 02:30 PM
Date registered: Jan 2015
Thumbs down Repasing the fuse creat a electrical short
My driver seat on my ckl 320 got stock on the forward position, i did replace the fuse located in the trunk and the seat move back but start smoking, something got burned and stop again, now I dot know what to do, were to begin looking, for the problem any ideas were should start checking to find the electric short?
Neptuno is offline
post #16 of 16 (permalink) Old 10-14-2015, 10:26 AM
Date registered: Oct 2015
I have the same problem. Seat won't slide forward or backward. I replaced all fuses - still nothing. Switch makes clicking noise when pressed but seat won't move. I checked the rails - no obstruction. Any advice?
Thanks.
First timer advice is offline
    CLK 320 REAR SEAT REMOVAL amarmotivala C208/A208 CLK-Class 1 10-11-2009 11:28 AM
    1999 CLK 320 cabriolet rear seat removal jhkanda C208/A208 CLK-Class 3 05-26-2009 02:31 PM
    Electric Seat not working - CLK 320...!!! Sunray General Mercedes-Benz 6 02-23-2009 02:22 PM
    CLK 320 seat motor Nor-Cal-CLK C208/A208 CLK-Class 2 04-26-2007 09:59 AM
    Octane of gas? Seat adjustment cover? Seat adjustment problem operagirl W126 S,SE,SEC,SEL,SD,SDL Class 13 08-23-2004 02:54 AM
