How do I remove a wire terminal from a weather proof connector? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 10-14-2009, 07:16 AM Thread Starter
Date registered: Jun 2009
Vehicle: 2005 E500
I need to remove a wire terminal from the three terminal Xenon headlight connector on my 2005 E500. Do you guys know how to remove the wire and terminal without damaging the connector or wire?
Thanks!
m4coyote is offline
post #2 of 6 (permalink) Old 10-14-2009, 08:20 AM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
I would just use a pair of needle nose pliers and gently pull the connector off.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
post #3 of 6 (permalink) Old 10-14-2009, 09:12 AM Thread Starter
Vehicle: 2005 E500
Thank you my friend, but I need to know how to actually remove a single wire and terminal from the actual plug itself. There are three wires in this plug, and I need to non-destructively remove one of them.
m4coyote is offline
post #4 of 6 (permalink) Old 10-14-2009, 11:21 AM
Date registered: Oct 2009
I do not know about the connector you are working with but some require a special tool to release the terminal. They ususlly have a smal metal tab that when the terminal is pushed into the housing the tab springs up and gets caught in a notch in the plastic terminal. If you look closely you might be able to see how it works. On some I have been able to insert a piece of thin safety wire or a minature screwdriver blade to depress the tab and allow the terminal to be pulled out.
terry s is offline
post #5 of 6 (permalink) Old 10-14-2009, 12:20 PM Thread Starter
Vehicle: 2005 E500
Thanks for the input. I believe that I will cut some small spring steel shims to slide in beside the terminal. Maybe that will allow it to slide free.
m4coyote is offline
post #6 of 6 (permalink) Old 10-14-2009, 02:52 PM
Good idea. That may work.
terry s is offline
    Need help on running a wire from the battery's positive terminal into the engine bay aibo W245 B-Class 14 04-20-2009 01:48 PM
    WIRE CONNECTOR HELP verdejor Audio & Telematics Forum 1 12-31-2008 10:59 AM
    Wire with no connector behind cluster getina50 W201 190-Class 5 05-18-2007 11:37 PM
    460 trailer wire connector to chassis harness ? Desertstar G-Class 8 03-28-2006 02:23 PM
    transmission OverLoad Protection Connector wire. rsmcmahon W140 S-Class 1 08-03-2004 05:14 AM
