2004 C230 parking light will not work. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-13-2009, 08:34 PM Thread Starter
Date registered: Oct 2009
The passenger side front parking light will not work. It shares ground with the headlight and the ground is good. I get no voltage to the + terminal at the bulb holder. The driver side works fine and it appears the same fuse is used for both sides.
Does anyone have any idea what the problem might be? It has never been in an accident that could have damaged the wiring harness.
Thank you for the help.
terry s is offline
post #2 of 3 (permalink) Old 10-14-2009, 08:29 AM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 22 Post(s)
Sounds like either a bad relay, or the wiring got messed up. Trace the wire back to see if it is still in good condition.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
post #3 of 3 (permalink) Old 10-14-2009, 11:26 AM Thread Starter
Thank you for the reply. The wiring dissapears by the headlight so I am not able to see where it goes. Is there a seprate relay for each side? If the parking lights are controled through a relay I would think one relay would control both so since the driver side is working the passenger side should work also.
terry s is offline
    Mods Pictures: Low Beam, Parking Light, Tail Light, License Light, Side Marker, ETC bs79 W211 E-Class 12 07-09-2009 03:01 PM
    passengers side parking light doesn't work kapp70 General Mercedes-Benz 3 05-05-2009 03:20 PM
    MY TAIL LIGHT AND FRONT PARKING LIGHT ARENT WORKING? HELP! DETANE W210 E50 AMG, E55 AMG 1 03-08-2006 02:49 PM
    MY TAIL LIGHT AND FRONT PARKING LIGHT ARENT WORKING? HELP! DETANE W210 E-Class 1 03-08-2006 10:02 AM
    Brake Light and Parking Light LED's installed: Two things you should be aware of S4toML W163 M-Class 6 02-23-2003 08:10 AM
