Changing Out Battery 1997 E320 - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 10-11-2009, 02:46 PM Thread Starter
Date registered: Oct 2009
What is the correct procedure as far as disconnecting and reconnecting?
jstarnes@mindspring.com is offline
post #2 of 4 (permalink) Old 10-11-2009, 03:06 PM
Musikmann's Avatar
Quoted: 6 Post(s)
You have a W210 and there is a forum devoted to these. Not that the procedure is that unique, but we have a section of DIY stickys, one of which will walk you through the steps. Briefly, there are a couple of things you need to re-synchronize after the reconnection step (windows, seats and sunroof come to mind) and you'll need your radio code.
Musikmann is offline
post #3 of 4 (permalink) Old 10-11-2009, 03:21 PM
Date registered: Aug 2005
This was the procedure I followed when I changed my battery (original MB which lasted eight years).
Disconnect Negative battery cable
Shape negative battery cable away from battery
Disconnect Positive cable
Remove battery clamp
Remove battery vent tubing & check condition
Remove battery
Clean battery area with mild mixture of water & baking soda, wipe with another damp cloth
Clean inside battery cable ends with battery cleaning brush till shiny
Clean new Interstate battery post with battery cleaning brush till shiny
Install battery & clamp down
Install battery vent tubing
Install felt washers over battery posts, these are available at parts store, reduces corrosion
Connect Positive battery cable, don't over-tighten
Connect Negative battery cable
Smear cable ends & posts with battery grease (parts store), helps reduce corrosion
I had to reset radio code & power window function which is explained in car manual
I hope this helps!
2000C230K is offline
post #4 of 4 (permalink) Old 10-11-2009, 06:59 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Your procedure sounds pretty good to me.
    Stumped: 1997 E320 runs with battery disconnected!!! firstbenzo W210 E-Class 3 01-06-2007 10:28 AM
    Changing oil on 1997 E420 questions ProV1x W210 E-Class 5 10-01-2006 06:18 PM
    changing water pump on 1997 C280 benz rider W202 C-Class 2 08-01-2006 06:52 AM
    Changing Battery 190_2.6 W202 C-Class 1 04-01-2004 07:21 AM
    Changing fluids on 1997 e320 leetec W210 E-Class 0 08-20-2003 09:25 PM
