Malfunction, then how long till CEL on - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-11-2009, 10:57 AM Thread Starter
Date registered: Aug 2005
Question Malfunction, then how long till CEL on
How long does a malfunction (P0170 code) have to exist before the CEL turns on? Does it turn on immediately when the malfunction happens? Then after solving the problem but not manually clearing the code, how long till code clears itself? I suppose this answer could be in time, miles, on/offs, driving conditions.
2000C230K is offline
post #2 of 2 (permalink) Old 10-11-2009, 02:01 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 78 Post(s)
P0170 should appear pretty fast if that problem exists. I do not know how long it lasts after the issue has been resolved, but if you do not have access to an OBDII scanner you could disconnect the neg terminal of you battery for a couple of minutes. The CEL should be turned off when you reconnect it.
Michael Pillay is offline
    1997 SL 500 roll bar malfunction & electric top malfunction Reed H R129 SL-Class 7 12-20-2007 07:38 AM
    Shoe pad lite. How long till I change pads Tbilisi79 W140 S-Class 13 12-11-2005 08:06 PM
    CEL....Fuel Trim Malfunction...HELP BRN2FLY W163 M-Class 4 11-28-2005 07:57 PM
    Cars from then till now... Thomas J W126 S,SE,SEC,SEL,SD,SDL Class 12 11-23-2005 01:29 PM
    First malfunction on my 2 months old car. (long) christophe -belgium- R170 SLK-Class 1 07-25-2002 04:18 PM
