vito misfire and white smoke - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-10-2009, 04:30 PM Thread Starter
Date registered: Oct 2009
Hi
My van was running fine (108cdi) apart from the fact it was losing water from the waterpump. I thought i would tackle this job, but after having a go in the rain i decided it was not for me. I took the van to a friend of a friends garage and they did the job for £90 (was ok with that) On collection of my van it now has a misfire and is pumping out white smoke, It is bad on tickover and at low revs, it sort of clears at higher revs. Engine is making usual nasty noises that come with this. Doing the job I know they had to remove the mount and drop the engine, my theory is that a pipe or wire may be damaged? as it was running fine when i turned it off, and a smokey pile of .... when they started it up!
freshwater21 is offline
post #2 of 3 (permalink) Old 10-11-2009, 02:12 AM
guardrail's Avatar
Date registered: Sep 2006
Vehicle: 2005 CL65 AMG
Did it overheat when it was losing water from the pump? It sounds like a head gasket. Does the white smoke have a sweet antifreeze smell? If they didn't bleed the air out of the cooling system it could have air locked and overheated. Have someone do a pressure check on the cooling system to see if it holds pressure. This would tell you for sure. It's a quick check to start eliminating things.
guardrail is offline
post #3 of 3 (permalink) Old 10-11-2009, 02:25 AM Thread Starter
Hi van did not overheat and have not noticed sweet smell. There is no loss of water since pump done the oil still looks good and there is no muck in oil filler cap. Would one of those plug in diagnostic boxes tell me if an injector was stuck or something like that?
vito misfire and white smoke freshwater21 V-Class 2 10-11-2009 09:24 AM
vito has misfire and white smoke freshwater21 General Mercedes-Benz 2 10-11-2009 01:01 AM
#8 Cylinder misfire with white smoke and oil leak SMotors W221 S-Class 10 05-30-2008 03:02 AM
310 Sprinter, Blue Smoke & Misfire 16v205 W901-905 Sprinter 2 12-03-2007 05:01 PM
E320 Misfire/Fuel smoke at idle & steady throttle Guest (MBNZ) W124 E,CE,D,TD Class 4 12-20-2001 07:13 AM
