vito has misfire and white smoke - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-10-2009, 04:11 PM Thread Starter
Date registered: Oct 2009
Cool vito has misfire and white smoke
Hi Im new to this site and its great to have found it
I have a turquoise vito with the windows in the side doors 2 seats in the back and amg rims. its perfect for what I need for work and the family, and I love it.
My van was running fine (108cdi) apart from the fact it was losing water from the waterpump. I thought i would tackle this job, but after having a go in the rain i decided it was not for me. I took the van to a friend of a friends garage and they did the job for £90 (was ok with that) On collection of my van it now has a misfire and is pumping out white smoke, It is bad on tickover and at low revs, it sort of clears at higher revs. Engine is making usual nasty noises that come with this. Doing the job I know they had to remove the mount and drop the engine, my theory is that a pipe or wire may be damaged? as it was running fine when i turned it off, and a smokey pile of .... when they started it up!
freshwater21 is offline
post #2 of 3 (permalink) Old 10-10-2009, 11:58 PM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
post #3 of 3 (permalink) Old 10-11-2009, 01:01 AM
white smoke
I had this happen to me on my 1975 280, If I recall right, the tran. fluid is making the white smoke, there is a line going maybe from carb down to the tran, there is a one way check valve there, I think its bad, been few yr.s ago,
atms is offline
    #8 Cylinder misfire with white smoke and oil leak SMotors W221 S-Class 10 05-30-2008 03:02 AM
    White Smoke ? ML 320 CDI W164 M-Class 8 12-18-2007 01:39 PM
    310 Sprinter, Blue Smoke & Misfire 16v205 W901-905 Sprinter 2 12-03-2007 05:01 PM
    White Smoke ?? ML 320 CDI W163 M-Class 9 11-24-2007 10:03 AM
    E320 Misfire/Fuel smoke at idle & steady throttle Guest (MBNZ) W124 E,CE,D,TD Class 4 12-20-2001 07:13 AM
