98 E430 Weird Electrical Problem - Help! - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-08-2009, 09:26 AM Thread Starter
Date registered: Oct 2009
This is driving me crazy. Randomly, different electrical things stop working (power windows & seats, power sunroof, etc.). They fail independantly at different times (except for things that are on the same circuit, i.e driver power window and power seat). It has even happended with the wipers and the trunk lid release, just not as frequent as the windows/seats. If I pull out the fuse for the circuit that no longer works and put the same one back in, everything on that circuit will start working fine (at least for a few days). Pulling out and putting back in the same fuse will only fix the problem if the ignition is on, it will not work with the key off. Removing the battery terminal and replacing it after a few seconds will also fix the problem. A brand new battery did not keep the problem from resurfacing. My Benz mechanic has no idea. Help!
tommy_ace is offline
post #2 of 2 (permalink) Old 10-08-2009, 07:24 PM
Date registered: Sep 2007
Vehicle: 99 Merc S420 (80k Mi) 07 Lexus LS460 (21k Miles)
Sounds like a grounding issue within the car. Something is shorting on the body or frame.
mr.xpowerseller is offline
    Weird Electrical Problem. HELP!! ahermster W203 C-Class 10 01-03-2009 05:48 PM
    Weird Electrical Problem busker W123 E,CE,D,CD,TD,TE Class 7 04-13-2008 12:53 PM
    weird electrical problem metricstar W124 E,CE,D,TD Class 5 11-12-2007 10:25 AM
    HELP: weird electrical problem lovemercedes2.8 W124 E,CE,D,TD Class 1 12-27-2005 07:36 PM
    Weird electrical problem Linc Fish W126 S,SE,SEC,SEL,SD,SDL Class 4 02-06-2004 12:53 PM
