NEED HELP URGENTLY!!ABS/BAS/ESP WARNING LIGHTS & WITH SHIFTER STUCK ON PARK, THANKS - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 10-07-2009, 02:21 AM Thread Starter
Date registered: Aug 2008
I have a 2004 CLK 320 , I was changing my head light bulbs last night and all the sudden, I noticed ABS/BAS/ESP/Brake wear and check engine warning lights were lit up on my instrument cluster. Also, the car stuck in park and cant move the shifter at all.
I have done some research on the forum, and says its the brake switch need to be replaced. So I went to the local mercedes stealer to buy the brake switch for our car. But i was told by the part dept. The CLK doesnt have the brake switch and it uses pressure switch and cost about $140. Since i am still don't know what the problem is, So i decided to come back to do some more research and ask people from this forum.
Please help as I really don't want to spend too much to get this sorted out. could it be the pressure switch?Also, is there a unlock shifter hole in our CLK,?so at least I can drive it to the shop Anyone else with this problem and what was the end result? Please kindly advise, Thank
Azndavid85 is offline
post #2 of 2 (permalink) Old 10-07-2009, 06:04 PM
imo
Date registered: Dec 2008
look at other area posted.
check the plug under the hood on drivers side near fender almost at top edge of fender above wheel right next to abs stuff...probably disconnected and failed to connect.
check fuses also.
imo is offline
    2004 SLK 230 problem: BAS/ESP light on; shifter stuck in park ruslan@global.t-bird.edu General Mercedes-Benz 4 10-06-2016 04:27 PM
    ABS/ BAS ESP lights on and cannot move out of Park dirtguy C208/A208 CLK-Class 11 05-15-2012 10:05 PM
    NEED HELP URGENTLY!!ABS/BAS/ESP WARNING LIGHTS & WITH SHIFTER STUCK ON PARK, THANKS Azndavid85 C209/A209 CLK-Class 5 10-10-2009 07:52 AM
    abs and bas esp warning lights rxphiler C208/A208 CLK-Class 9 10-29-2007 10:33 AM
    ESP/BAS & ABS warning lights in A-140 johnmanoj1 W168 A-Class 3 08-30-2006 09:13 AM
