MB Tail lamp assembly - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 10-03-2009, 06:53 AM Thread Starter
Date registered: Jul 2008
Where can I find a rear tail lamp assembly picture for my 2004 CLK 500?
I get a warning that my left rear tail lamp is out but I'm not sure which bulb is which when I went into the assembly.
Any help is much appreciated
bucksfan is offline
post #2 of 3 (permalink) Old 10-03-2009, 10:37 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Here's a thought, probably too obvious to work, but give it a try. Turn your lights on, go to the back and see which bulb is NOT lit on the affected side. Replace said bulb.
You're welcome.
flyboyike is offline
post #3 of 3 (permalink) Old 10-03-2009, 11:33 AM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Yes, you'll probably have to compare the left to the right. The are mirror images.
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
    Tail lamp/break lamp left! ed W164 M-Class 1 07-04-2009 08:23 AM
    need to get interior lamp assembly?? amgstyle R170 SLK-Class 4 03-05-2008 04:51 AM
    DIY: Installing w220 styled tail lamp assembly? saimasta W203 C-Class 3 04-27-2007 02:50 PM
    Tail lamp assembly recall pepe.valdez R170 SLK-Class 2 11-14-2006 02:53 PM
    european head lamp assembly Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 2 01-23-2002 08:31 AM
