79 450SL - Help with Climate Control Sensor- New Dashboard Cap - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 10-02-2009, 09:15 AM Thread Starter
Date registered: Sep 2009
Greetings - I purchased a new dashboard cap to sit on top of my cracked dashboard (a very common problem I am told from this era). Everything I have read says to pull the 2 hoses from the climate control sensor on the top of the dash so that a new hole can be drilled in the new cap. The problem is that under the hoses I have wires apparently soldered to the sensor...I called the manufacturer of the cap and they seem suprised too. Has anyone run across this or have suggestions? I will most likely let my mechanic do the work as the unit doesnt want to come apart where there is an apparent seam on the plastic, and I dont want to unsolder anything with the very tight wires...as I drop them into the dashboard never to bee seen again..
79 450SL is offline
    78 450SL - Climate Control stuck on Heat Mezquite R/C107 SL/SLC Class 17 12-03-2015 08:31 AM
    1978 450SL climate control problem dravera R/C107 SL/SLC Class 10 05-11-2009 05:13 AM
    450SL - how to determine functionality of climate control supercanuck R/C107 SL/SLC Class 3 05-07-2008 04:32 PM
    '80 450SL - How to run AC without Climate Control supercanuck R/C107 SL/SLC Class 8 08-28-2007 05:58 AM
    450SL '80 Climate Control china blue R/C107 SL/SLC Class 0 10-08-2002 10:58 AM
