headlights.. strange.. issue? - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-27-2009, 08:05 PM Thread Starter
TimmahW123's Avatar
Date registered: Aug 2009
Vehicle: 1991 Mercedes Benz 300D 2.5T, 270,000 miles & counting
Quoted: 30 Post(s)
Ok... heres the deal.. I replaced the driver's side lamp a while back. It would work on highbeam.. but not on low beam. When I replaced it, same thing. Today I went through and replaced every/single/fuse it needed to be done.. and im still having the same problem.
basically before i did this.. id have my headlights on.. and the pass. side lamp would work along w/ fog lights and it would be ok. i could turn on the high beams but that would shut off the pass side headlight and turn the high beam on in the driver side.
when i replace the fuse both highbeams work but still cannot get the drivers side one to turn on. so im thinking., wahat are some possible troubleshooting steaps i can take to fix this
TimmahW123 is offline
post #2 of 3 (permalink) Old 09-28-2009, 07:07 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 67 Post(s)
I'd check the headlight relay, headlight switch and the multifunction switch in that order.
flyboyike is offline
post #3 of 3 (permalink) Old 09-28-2009, 07:19 AM
Swauve's Avatar
Date registered: Mar 2009
Vehicle: 2002 CLK 430 & 1989 Camaro RS Fuel Injected
Stereotypes are never 100% false!
"Life is fraud when your fake, but it's so hard when your real."
"A lie has speed, but truth has endurance." -Edgar J. Mohn
"What up black cop, every brother ain't no brother." -Styles P
"Fat people on elevators are self explanatory and count as two for safety reasons."
"...and if you're going to die for a cause let be cause I was high, and they tried to take the Benz!"
G's Up...
Swauve is offline
    Strange issue solstice W163 M-Class 5 06-04-2009 05:09 AM
    HELP? Strange headlight issue Slick98 R170 SLK-Class 6 03-26-2009 12:42 PM
    Strange starting issue NZ Benz W140 S-Class 27 05-30-2008 12:27 AM
    Strange electrical issue? AlphaWolf W210 E-Class 9 05-15-2008 06:55 AM
    Strange little radio issue... Check Codes W210 E-Class 7 03-18-2008 05:16 PM
