Very bad loss of power or missing? - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-19-2009, 11:52 PM Thread Starter
Date registered: Aug 2009
Vehicle: 02 E320 wagon
Question Very bad loss of power or missing?
I have an 02 e320 wagon, I will give all the details I know when this problem abruptly happened. I was gunning it around a corner in the rain, I had my plastic cover off from changing the oil, at high revs just before it was going to shift it hiccuped like the over rev sensor cut in, just a few 100 feet after that when I gave it throttle it acted like it was out of gas. If I backed of the peddle it would catch again for a minute and then either have a huge loss of power or act like it was out of gas again. It has consistently done this for about 3 days now, once even hiccuped again and went into limp mode with the "BAS/ESP" light coming on, so I had to pull over and turn the car off and restart it and it was back to the same erratic problem, that light went out. Never a check engine light through all of this though. Any advise would be greatly appreciated. Thanks, John
soundchoiceav is offline
post #2 of 5 (permalink) Old 09-20-2009, 12:04 AM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Hi, John.
First things first. Please click the user cp link and add your vehicle and location to your profile as that is often useful information.
Second, you've posted a rather technical issue into the general forum, but generally you'll get more useful information if you post in the forum that is specific to your chassis, which is the W210. Scroll down to the sedans forum and you'll see it.
Third, the first step I would take is to check for codes. Codes can set even if you don't have a CEL, and they can be very instructive when you're chasing symptoms. Once you get codes you can search them on the forum or post in the 210 forum and the folks there will probably get you squared away.
(I won't comment on the advisability of gunning it around a corner in the rain...)
Check Codes is offline
post #3 of 5 (permalink) Old 09-27-2009, 09:23 PM
Date registered: Aug 2004
loss of power
May be one of your cats- I have seen it when one gets clogged it will cause it to run bad and mis, making it basically un-driveable. The other maybe the MASS Airflow Sensor.
wayne.hyde is offline
post #4 of 5 (permalink) Old 09-27-2009, 09:30 PM
TimmahW123's Avatar
Vehicle: 1991 Mercedes Benz 300D 2.5T, 270,000 miles & counting
Quoted: 30 Post(s)
O2 sensor or failed catalytic converter.
TimmahW123 is offline
post #5 of 5 (permalink) Old 09-28-2009, 06:24 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 81 Post(s)
Agreed. Also check the throttle position sensor.
In the ML320, if you turn your wheel all the way to one side, then all the way to the other side-back and forth-the BAS/ESP light will go off.
I do not know if this will work on your mdel, but it is worth a try.
Mike
Michael Pillay is online now
    Power loss kenrice@eircom.net General Mercedes-Benz 0 11-13-2008 03:34 AM
    help bad smoke and loss of power (bogging) keimini W123 E,CE,D,CD,TD,TE Class 4 07-25-2008 12:01 AM
    SLK32 power loss. bad IC pump? maybe not this time... rasoul R170 SLK-Class 5 03-24-2008 08:29 PM
    420 lo spd missing cause=bad plug wires dan1 W126 S,SE,SEC,SEL,SD,SDL Class 4 07-19-2006 05:44 AM
    Power Loss davey W201 190-Class 4 07-26-2003 03:05 PM
