Will these wheels fit? - Mercedes-Benz Forum
post #1 of 6 (permalink) Old 09-18-2009, 02:51 PM Thread Starter
Date registered: Jul 2009
Hi, I own a 1987 300SE, and am looking at purchasing some wheels. I am unsure what other wheels can fit, however, I have been offered these....
4 X Genuine Mercedes Benz 16" Alloys to suit all SLK & C Class models
I would be greatly appreciated if someone could tell me if these will fit. If not, what other Mercedes wheels will fit my 1987 300SE?
Thank you.
TheFat is offline
post #2 of 6 (permalink) Old 09-18-2009, 02:54 PM
Kajtek1's Avatar
Quoted: 1226 Post(s)
Welcome to the forum.
MB have very wide variety of wheels and the answer might not be an easy one.
Most of the bolt patterns are the same, but offset and width wary a lot.
Compare the bolt pattern and offset of the rims. On MB wheels the numbers are molded on the inner side of the wheel. There is pretty good tolerance in changing the wheels for different size, but it eventually ends. Go to your car section for specific answer.
Kajtek1 is offline
post #3 of 6 (permalink) Old 09-21-2009, 04:55 PM
Date registered: Sep 2009
Thank you for the answer.
bimmer4life2009 is offline
post #4 of 6 (permalink) Old 10-28-2009, 11:23 AM
Date registered: Oct 2009
Cool, thanks for the info
mikeps3speed is offline
post #5 of 6 (permalink) Old 10-28-2009, 07:43 PM
Premium Member
roncor's Avatar
Date registered: Jan 2005
Vehicle: '91 420 SEL, '80 240D, '87 560 SL, '93 190E Sportline, '70 300 SEL 6.3
Quoted: 41 Post(s)
Premium Member
Here is a fitting chart:
Mercedes AMG BMW new used & refurbished alloy wheels & tyres, UK wheel alloys
roncor is offline
post #6 of 6 (permalink) Old 10-29-2009, 09:40 AM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 86 Post(s)
The offset on the slk rims will be much too high for your w126. Do a search on the w126 forum. There is a lot of info on which wheels will fit our vehicles.
Mike
Michael Pillay is offline
    Wheels/Tires HELP-19x8.5 wheels w 245/35/19 - will they fit front of W210 4matic??? das_benz W210 E-Class 0 05-01-2008 09:41 AM
    will s or cl 19 inch wheels fit on a 2001 c240 and if not can i make them fit and still look good? loweredbenz The Discount Tire Direct Tire, Wheel, Brake & Suspension 2 02-04-2003 05:15 AM
    Will the lug bolts from standard 17" wheels fit the 18" AMG wheels??more RezaH R230 SL-Class 1 10-26-2002 09:58 PM
    Anyone know where the best deal is on ML55 wheels? What All season tires fit the 18" wheels?? JPinTO W163 M-Class 12 01-24-2002 11:02 PM
    Will 10 in. wide wheels fit on the rear of an slk, how about 9.5 in. wide wheels, all 18 in. diam. Guest (MBNZ) The Discount Tire Direct Tire, Wheel, Brake & Suspension 0 10-30-2001 01:16 AM
