leaking oil front of engine - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-17-2009, 04:31 PM Thread Starter
Date registered: Sep 2009
Vehicle: 1995 S500
At normal driving it does fine on the expressway it throws oil across the front of motor
lharris502 is offline
post #2 of 3 (permalink) Old 09-17-2009, 04:36 PM
Check Codes's Avatar
Vehicle: '01-E320 & 02-ST2
Quoted: 35 Post(s)
Wow.
Since I don't have my magic lamp, here's a couple of suggestions.
Please click the user cp link and complete your profile to include vehicle and location information, that is often useful information.
Second, the general forum is for just that, general information about MB. Since you have a specific question about some vehicle (I assume it is an MB at least) scroll down the forum page until you find the specific forum for your vehicle, then post in there.
However, before you repost, consider that it can be very hard to diagnose an issue on a forum. So instead of being cryptic and barely describing the issue, add some more detail...lots of it. Mileage, last service, where the oil appears, etc. That will help those in the destination forum to give you some advice and suggestions.
Good luck, hope it's something easy. And cheap!
Check Codes is offline
post #3 of 3 (permalink) Old 09-17-2009, 04:43 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I seem to have mis-placed my crystal ball too.
Musikmann is offline
    1991 oil Leaking in front of the right rear wheel Bigpauly52 R129 SL-Class 26 07-13-2014 04:36 PM
    Leaking oil seals at front of camshafts - please help S class W140 S-Class 3 02-28-2006 07:52 PM
    Leaking oil from engine sensor near engine mount falconsprint W126 S,SE,SEC,SEL,SD,SDL Class 9 01-22-2006 08:35 PM
    Leaking oil on the engine! Help! tempoct R170 SLK-Class 8 08-19-2004 09:23 AM
    Engine oil and Transmission fluid leaking az2md W210 E-Class 0 01-03-2004 08:08 PM
