Wiring diagram and pin outs for V6 engine control unit - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 09-15-2009, 02:41 PM Thread Starter
Date registered: Apr 2009
Vehicle: SL320 V6
Hi, I am petty new here and have been looking for any links/info on finding details of the pin outs for the ECU for a 2000 SL320 with a V6 112.943 engine. I have spent he last 3 hours searching on here and google etc. I assume other vehicles with the same motor use the same ECU like the S320 or ML320
Any help would be appreciated.
Thanks
AMcK is offline
post #2 of 5 (permalink) Old 09-15-2009, 03:21 PM
Date registered: May 2005
Vehicle: '07 GL320CDI
Quoted: 2 Post(s)
Star Service CDs and DVDs
Kent Christensen
Albuquerque
'07 GL320CDI
lkchris is offline
post #3 of 5 (permalink) Old 09-15-2009, 03:28 PM Thread Starter
Vehicle: SL320 V6
Originally Posted by lkchris View Post
Thanks for reply. I did find these for sale, but they don't seem to be for sale in the UK (sorry hadn't put my location in original post - profile updated). They also don't list the 112 engine.
AMcK is offline
post #4 of 5 (permalink) Old 09-15-2009, 09:40 PM
Diesel Benz's Avatar
Quoted: 39 Post(s)
Do you run a business, then you can purchase access to the same info on-line here:
Daimler AG - Service & Parts net
Unfortunately this is not available if one does not have a VAT account.
Would you mind explaining what are you after with the pin diagram, do you have some issues that you want to diagnose?
Diesel Benz is offline
post #5 of 5 (permalink) Old 09-17-2009, 03:07 PM Thread Starter
Vehicle: SL320 V6
The car is my own and although I do run my own business it is not VAT registered (and has nothing to do with cars)
I am after the pin outs to sort out a problem caused by a garage. I had the car converted to run on lpg on Monday. They have spliced into the loom at the ECU. My understanding is they will have cut in to each injector signal and an rpm signal and a ignition controlled +ve. The problem is since fitting the engine malfunction indicator lamp no longer illuminates when the ignition is switched on. So I want to be able to check exactly what the wires are for they have spliced into and if there are alternatives to try to sort the lack of MIL.
AMcK is offline
clocks pin outs bazw W901-905 Sprinter 0 03-26-2007 07:43 PM
Need a center console wiring/pin diagram Babushka W203 C-Class 2 12-10-2006 06:07 PM
Phone System Wiring Diagram and Pin Outs dbarakat Audio & Telematics Forum 2 08-10-2006 10:38 PM
Help W201 UK 2ltr 15 pin wiring diagram grelco W201 190-Class 1 06-27-2006 10:21 AM
Comand pin-outs Guest (MBNZ) Audio & Telematics Forum 3 12-03-2001 01:10 AM
