2001 ml320 engine oil leak - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-13-2009, 07:00 PM Thread Starter
HERSOG's Avatar
Date registered: Apr 2008
Vehicle: 2001 ml 320 modified to go off road
Post 2001 ml320 engine oil leak
Hello everyone, I have a 2001 ml with 113,000 miles on it, and I bought it brand new. I have an engine oil leak on the back where the bell housing is mounted to the engine. The other day when I was servicing the starter unit and when it was removed I noticed the oil residue around the frame where the starter mounts to the engine and it is coming from the inside and not out side. And I can tell you when I am under the truck and looking up only the right side is wet, not the left side. And I have checked everything. The valve cover is dry, and the fly wheel is also dry. Thanks for the help.
HERSOG is offline
post #2 of 3 (permalink) Old 09-13-2009, 07:50 PM
Michael Pillay's Avatar
Date registered: Oct 2003
Quoted: 78 Post(s)
If you have a technical question, it is more likely to be answered in the w163 forum than here. This is just a place to introduce yourself. Welcome to benzworld. I am sure someone in the w163 forum can help you.
Michael Pillay is online now
post #3 of 3 (permalink) Old 09-13-2009, 10:35 PM
leapyfish's Avatar
Vehicle: 1998 SLK230 199,xxx Miles
Quoted: 4 Post(s)
leapyfish is offline
    Engine oil leak - front pulley oil leak? southbusiness W210 E-Class 4 04-25-2009 05:41 PM
    Oil leak on 99 ML320 CO-ml320 W163 M-Class 20 11-29-2007 03:02 PM
    Engine Oil Leak -- 00 ML320 sundeac W163 M-Class 3 02-25-2007 07:52 AM
    Repair Costs for very slight oil leak at phenolic (sic) oil filler cap, 2001, 320 noelchambers R170 SLK-Class 2 11-05-2005 07:53 AM
    98 ML320 - Oil Leak sl320man W163 M-Class 4 11-14-2004 03:53 PM
