window doesn't work - Mercedes-Benz Forum
post #1 of 10 (permalink) Old 09-08-2009, 08:35 AM Thread Starter
Date registered: Sep 2009
window doesn't work
my rear driver side window stopped working. i could here the motor running when i pushed the switch but no up or down. when i opened the doop panel i discovered two cables dangling with spring loaded endings and white broken pieces of plastic that once attached the two ends of the cables. what i would like to know is if i can replace the plastic piece or do i have to purchase the the entire assembly (minus the still working motor). can anyone please provide some input?
1dreemer is offline
post #2 of 10 (permalink) Old 09-08-2009, 09:15 AM
Date registered: Apr 2009
Vehicle: 1999 E300TD
you need a new window regulator and its the whole assembly, what kind of vehicle E-class?
saleen1276 is offline
post #3 of 10 (permalink) Old 09-08-2009, 09:23 AM Thread Starter
Thanks for the response. It's a 1999 E320. Do I need a rivet tool to install it myself and do you have any idea of the cost to have it repaired if I go that route?
1dreemer is offline
post #4 of 10 (permalink) Old 09-08-2009, 09:32 AM
yes , there are 5 rivets that hold the regulator to the door. you will need to frist drill out the old ones. the part is approx $140 and if you take it to a dealer expect to pay about $250 to $300 in labor...where are you located??
post #5 of 10 (permalink) Old 09-08-2009, 09:41 AM Thread Starter
I'm in Los Angeles
1dreemer is offline
post #6 of 10 (permalink) Old 09-08-2009, 10:43 AM
leapyfish's Avatar
Date registered: Apr 2008
Vehicle: 1998 SLK230 210,xxx Miles
Quoted: 5 Post(s)
leapyfish is offline
post #7 of 10 (permalink) Old 09-08-2009, 10:44 AM
Date registered: Apr 2006
Vehicle: 12E350, 12ML350, 08C350
Originally Posted by 1dreemer View Post
I'm in Los Angeles
Order part online (autohausaz dot com) @ $85.00 (for the rear left window regulator, free shipping & free CA tax). take it to a MB mechanic (I took it to an autoglass shop close to my house, charge me $50.00, I am in OC) with rivet machine to hold the window regulator really good. Synchronize the window after installation (the shop do not know how to sync the window). I check the dealer : it's $400.00 then I read the DIY thread (on top of W210 section), save me some $$. PM me if you need any help.
00CLK208 is offline
post #8 of 10 (permalink) Old 09-08-2009, 04:17 PM
Supporting Vendor
FCP Euro's Avatar
Date registered: Jul 2008
Quoted: 23 Post(s)
Welcome to BenzWorld. Hope you get this all figured out. You can get a hand riveting tool from sears to redo the rivets. It works really well.
Quality & Service, Guaranteed for Life
FCP Euro - OEM & Genuine European Auto Parts Online
FCP Euro is offline
post #9 of 10 (permalink) Old 09-15-2009, 09:55 AM Thread Starter
Many thanks. I bought the regulator, used my brothers rivet tool, fixed the window and saved some significant $$
1dreemer is offline
post #10 of 10 (permalink) Old 09-15-2009, 10:06 AM Thread Starter
Thanks. Wish I'd seen your post earlier, would've saved evem more $ on the part. But what the hey, I got it from the dealer, removed the rivets and regulator, replaced them and saved apprx $250.00 to $350.00 anyway. Didn't do anything to sync but it's working fine. Thanks again
1dreemer is offline
    This girl's window won't work!!! lynx R170 SLK-Class 9 08-21-2009 05:30 PM
    RIGHT WINDOW SWITCH DOES NOT WORK Barook Agra R129 SL-Class 2 06-07-2009 03:49 AM
    Window parts - 90-93 work in 86-89? staticbadger W124 E,CE,D,TD Class 2 12-02-2006 08:01 PM
    window regulator - 90-93 work for 86-89? staticbadger W124 E,CE,D,TD Class 0 11-23-2006 10:57 AM
    Window dosent work Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 3 08-22-2002 08:56 AM
