S 600 Sedan transmission problem - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-07-2009, 06:11 PM Thread Starter
Date registered: Aug 2007
Hi Guys,
I bought this S600 nearly 4 years ago with 86000 miles on it. On rare occasions, the transmission would do a delayed down shift, hitting hard when the shift occurs. I think it was shifting from 3rd or 4th down to 2nd. It didn't happen but about once in 6 months. Other than this problem it is perfect in every way.
Now with 115,000 miles the problem has gotten worse. The 2-3 upshift is a little delayed and harsh. The down shift under full throttle at speeds over about 40 mph are real hard-the wheel spin light comes on momentarily.
I've had it to the MB dealer twice; they say that there are no codes being set; think the trouble is internal. Cost of them rebuilding is about $7000.00.
I talked with a couple of transmission shops and they wonder since this is the 5 speed computerised tansmission, that it may have a solenoid problem that is giving the problem.
Question; I hate the expense and if it is a small solenoid problem; why does the whole transmission have to be rebuilt when it has worked well for the last 4 years.
What do you think?
John Logsdon is offline
post #2 of 3 (permalink) Old 09-07-2009, 06:46 PM
Date registered: Apr 2009
Vehicle: 1999 E300TD
John, it does sound like a solenoid problem and without any codes being set it can be hard to diagnose. They also have a lot of problems with the valvebody, which is basically the brains of the transmission. From my experience if the fluid is in ok condition and not completely burned up I would replace the entire valvebody which will come with the electrical plate (all of the solenoids are included with the plate). The valvebody will run you approx 1400 i think plus a few hours labor. Also make sure you check the transmission module to make sure there is no fluid in it . The fluid can actually get sucked up through the wiring and damage the module . If I remember it is located under the carpet of the front passenger.
saleen1276 is offline
post #3 of 3 (permalink) Old 09-08-2009, 06:22 PM Thread Starter
S600 transmission problem
Saleen, thanks for your reply.
The suggestions you made make sense. I will start down that road.\
Thanks, John
    722-600 transmission timlock W210 E-Class 5 10-05-2014 04:52 AM
    1966 600 Series Automatic Transmission Problem wawoola Vintage Mercedes-Benz 3 03-01-2008 08:10 AM
    1978 Mercedes 300D diesel sedan - $600 P4olom W123 E,CE,D,CD,TD,TE Class 6 04-03-2007 07:47 PM
    For Sale: Used Mercedes 1960s Automatic Transmission - GOOD SHAPE - $600 ameister For Sale/Wanted/Trade/Giveaway 0 07-16-2006 12:30 PM
    SL 600 ADS problem lowanover R129 SL-Class 3 09-20-2003 02:34 AM
