1984 500SEL Transmission Fluid/Tranmission Question - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 09-07-2009, 02:49 PM Thread Starter
Date registered: Dec 2008
Vehicle: 1984 Mercedes-Benz 500SEL
Post 1984 500SEL Transmission Fluid/Tranmission Question
Hi
I was wondering if anyone could tell me what type of Transmission fluid I should put in my 1984 500 SEL W126. I noticed the other day as I was driving the transmission may have slipped a little bit, and I think its time to replace the transmission fluid, gasket, and filter, etc. Any advice in this situation would def help, also if you know where to get the recommended transmission fluid, that information would also be a great deal of help to me!
Thank you!
mercedesdudeCA is offline
post #2 of 7 (permalink) Old 09-07-2009, 04:35 PM
Musikmann's Avatar
Quoted: 6 Post(s)
Have you tried a search on the W126 forum (look in the sedans section below) or looked in your owner's manual? Any MB dealer should be able to tell you plus sell you the fluid unless you are looking for an aftermarket equivalent. I'm sure those are readily available for a car that old.
Musikmann is offline
post #3 of 7 (permalink) Old 09-07-2009, 06:51 PM
Date registered: Jul 2004
Quoted: 311 Post(s)
The short answer is Dexron but it gets a little more complicated with the numeric suffix. Your car would have been Dexron II when it came out, which was replaced by Dexron III, and recently by Dexron VI, what happened to IV and V I don't know. For more info see - DEXRON - Wikipedia, the free encyclopedia
I think you're fine with Dexron III, if you should find it, or a Dexron III look alike (Dex/Merc), or Dexron VI. I saw something once about III being better for old cars than VI, but I can't remember what it was, and I suspect that one day we're not going to have a choice. No need to go to the dealer - you can get them anywhere.
deanyel is online now
post #4 of 7 (permalink) Old 09-08-2009, 07:57 AM
Date registered: Sep 2009
I have a 87 420 sel, im having the same problem, after you changed the fluid and screen, did it make a difference? Im scared to, because i was told that it could make the tranny worse by cleaning out the debris thats in there.
Therron0528 is offline
post #5 of 7 (permalink) Old 09-08-2009, 10:52 AM
Musikmann's Avatar
Quoted: 6 Post(s)
The only issue I've heard regarding debris is if you power flush your tranny and therefore dislodging a bunch of stuff better left where it is. A simple drain/refill with a filter change should present no problem.
post #6 of 7 (permalink) Old 09-16-2013, 09:09 PM
Date registered: Mar 2013
Transmission Service
I am going to the following service on my 1984 300SD Transmission.
1. Drain the transmission pan.
2. refill with sacrificial Import ATF.
3. Run the car through the gears.
4. Drain the Transmission pan.
5. remove transmission pan and filter.
6. install new filter and transmission pan with new gasket.
7. refill with sacrificial ATF.
8. Run car through gears.
9. Drain Transmission pan
10 Refill with AMSOIL Universal synthetic ATF.
Did a similar service to 2007 BMW 328i using Redline Synthetic ATF and no issues have developed.
jclassboat is offline
post #7 of 7 (permalink) Old 09-17-2013, 04:44 AM
flyboyike's Avatar
Date registered: May 2003
Vehicle: 2012 Focus SE
Quoted: 69 Post(s)
Noted, thanks.
flyboyike is offline
    92 500SEL Transmission question eatmydave W140 S-Class 6 05-31-2009 12:30 AM
    1984 500sel o2 question mercedes84black W126 S,SE,SEC,SEL,SD,SDL Class 6 03-18-2007 08:18 PM
    1984 500sel injector question/ high mileage mercedes84black W126 S,SE,SEC,SEL,SD,SDL Class 1 12-30-2006 02:30 PM
    1984 500sel injector question mercedes84black W126 S,SE,SEC,SEL,SD,SDL Class 7 12-30-2006 02:11 PM
    Anyone need parts for a 500sel, I have 1984 500sel parting out nckmsn For Sale/Wanted/Trade/Giveaway 0 04-19-2005 02:06 PM
