SRS airbag light on - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 09-07-2009, 06:57 AM Thread Starter
Date registered: Sep 2009
Vehicle: 2004 Mercedes C240 4matic
SRS airbag light on
I own a 2004 C240 4 matic with 57,000 miles on it.The srs light went on,and the message said drive to workshop now!Its labor day weekend here in the states and i was on my way to the lake. I figured the airbag systym would just shutoff if i kept driving(taking a chance i know).Well the light is still on and at 1 point the cd player stopped working,it said on the dash "no cd player".The next day the cd player worked but the automatic window function would not work when i pushed for the windows to go up.Later 2 of the windows did go up automatically but the other 2 didnt.Never had these problems until the srs light came on.Also i should mention that before the light came on sometimes when i pushed the up or down button on the steering wheel the horn would blow.Ever since i bought the car when i kept my finger on the + button on the steering wheel to raise the volume on the radio the horn would blow.Im not sure but im thinking there might be a problem in the steering wheel.Any thoughts or ideas would greatly be appreciated.
speddy is offline
post #2 of 14 (permalink) Old 09-07-2009, 10:20 AM
Musikmann's Avatar
Quoted: 6 Post(s)
On the surface these symptoms appear unrelated but they probably are not. One thing you can check is the battery. Low batteries can cause all sorts of odd electrically related things.
Musikmann is offline
post #3 of 14 (permalink) Old 09-08-2009, 04:45 PM Thread Starter
I checked the battery,it checked out fine.I replaced it anyways.It is about 6 years old.I figured it was gonna go soon anyways.I still have the original problem.Any other thoughts or ideas?
speddy is offline
post #4 of 14 (permalink) Old 09-08-2009, 06:10 PM
imo
Date registered: Dec 2008
according to repair pal website
for year and model.
* Brake light switch failure can cause the ESP and BAS warnings to illuminate.
* A bad seat control module can cause a dead battery. Spilling liquid on the front seats can cause these modules to fail.
* CD changers suffer from internal mechanical problems and may need replacement.
* The SRS (airbag) light may illuminate if liquid is spilled into the seat belt buckles or pools underneath the seat and gets into the electrical connector for the seat belt pretensioners.
I think it may be related to some kind of short or intermittent connection.
imo is offline
post #5 of 14 (permalink) Old 09-08-2009, 07:16 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I think I would also start a thread on the W203 forum so you capture the attention of some other actual owners. Whoever sees your thread here is hit or miss. I own a different car and the other poster probably does too. Back to your problems now.
SRS Light could also be due to a bad weight sensing pad in the passenger seat. It's purpose is to sense the weight of the person sitting there. If under about 60 lb it inactivates the airbag.
CD player/changer is one of the components that are connected to others in the D2B fiberoptic loop. If it is not recognised by the car, it can malfunction. If this is the problem it will take a dealer, or someone else with the Star diagnostic system to code it into the car's system.
Windows might be due to liquid having been spilled around the master switches. At least on my car, they are connected together on a single circuit board and under the center console.
Horn might have something to do with the steering wheel since that's the only place I know of to activate it (make it blow). I have never had one apart so I don't know how close the +/- button wires are to those involved with the horn.
One last thing is your car has a CAN/BUS system that links certain components together. I don't understand it at all but it has been blamed for any number of strange electrical-type problems like with the bad battery I mentioned earlier.
post #6 of 14 (permalink) Old 09-09-2009, 02:44 PM Thread Starter
I bit the bullet and took my car to the shop.It turns out it was the battery.The voltage was off on everything that was out of wack and set codes off.They reset the srs, reprogrammed the windows and cleared all the other codes.The car seems fine now.Hopefully it stays that way!
speddy is offline
post #7 of 14 (permalink) Old 09-09-2009, 04:46 PM
Musikmann's Avatar
Quoted: 6 Post(s)
But you told us you replaced the battery, I don't understand?
post #8 of 14 (permalink) Old 09-09-2009, 04:52 PM Thread Starter
I did replace the battery,but apparently the old battery screwed everything up.Once things go out of wack they stay that way until they are reset or reprogammed with the garages scanner.
speddy is offline
post #9 of 14 (permalink) Old 09-09-2009, 04:57 PM
Musikmann's Avatar
Quoted: 6 Post(s)
I see now, thanks for explaining. In other words there were a lot of stored error codes that had to be cleared.
post #10 of 14 (permalink) Old 09-09-2009, 05:01 PM Thread Starter
Yea exactly.Some things also needed to be reprogrammed.I drove the car for about 2 hours since the garage did that and its been fine so far.(Knock on wood).I hope it stays fixed lol.
speddy is offline
560SL airbag/SRS light sokoloff R/C107 SL/SLC Class 20 08-31-2015 04:55 PM
SRS + Pass AirBag Off Light mlx52 W163 M-Class 5 08-03-2010 02:54 AM
SRS and Airbag light almost always on ALT W210 E-Class 3 09-01-2007 02:57 AM
SRS/Airbag Light dmico2 W163 M-Class 6 08-18-2005 10:16 PM
SRS (AIrbag) light on huapi23 W163 M-Class 2 04-10-2005 08:35 PM
