Clutch issue with my 300 GD 1986 - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-05-2009, 06:21 PM Thread Starter
Date registered: Sep 2009
Vehicle: 1986 Mercedes Benz 300 GD 4x4 Gelandewagon
Send a message via AIM to britishcolumbia Send a message via Yahoo to britishcolumbia Send a message via Skype™ to britishcolumbia
Exclamation Clutch issue with my 300 GD 1986
I went away on a mountain for a weekend, lots of off-roading was had. I was on logging roads at relative speed (60 KM/HR or 35 MPH) and lots of steep hills. It wasn't to the point that I had to use the differential locks, but it was good off roading. I put my benz to rest, no damage was done. A few days later I go to give it some exercise, and it fires up perfectly, I press the clutch, and attempt to put it into reverse, it grinds and wont go into any other gear. I push the clutch a few times, exercise it, no change. I start and stop the motor, rock the car, everything. I even started it in gear with the clutch "engaged" and the starter moved the car. It was in perfect shape when i returned from my off-roading adventure, I'm not sure what could have caused this. Any thoughts? I know its my clutch, but I don't know much about it as i haven't had this wagon for long. Any input will be appreciated.
britishcolumbia is offline
    406 Clutch Issue snaplane2 Unimog 5 07-17-2007 10:16 AM
    406 Clutch Issue ted gates Unimog 1 02-11-2007 08:18 AM
    wiring diagram for compressor clutch, 1986 560sl jako R/C107 SL/SLC Class 0 08-26-2005 02:43 PM
    Clutch Issue Mike G. G-Class 6 04-09-2005 10:31 AM
    1986 560SEL sunroof issue blazer W126 S,SE,SEC,SEL,SD,SDL Class 4 12-08-2003 12:33 PM
