87 420SEL Transmission Issues - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-04-2009, 07:33 AM Thread Starter
Date registered: Sep 2009
Vehicle: 1987 420 SEL
I have a 87 420 SEL with automatic transmission. It has developed a problem when driving. When in drive it goes fine for a bit then it seems to just drop out of gear and the engine just revs as in neutral. If you shift down to 3rd then it kicks back in and runs fine but won't shift up to the final drive. If you start out with it set for 3rd it runs fine, but still won't shift above 3rd of course. I'm would like to know what I should check and in what order. I have topped up the ATF fluid level and am in the process of checking for leaks. Thanks for any info you can pass my way.
okcraig is offline
    Transmission issues (1990 300E, 3.0L, 722.5 transmission) Eric@StarSuzuki W124 E,CE,D,TD Class 5 04-13-2011 07:29 PM
    89 420sel transmission problems benz_man101 W126 S,SE,SEC,SEL,SD,SDL Class 6 05-26-2009 09:06 PM
    420SEL transmission in a 300SEL? Extrordnry25 W126 S,SE,SEC,SEL,SD,SDL Class 3 05-25-2009 11:48 PM
    420sel air issues? Qxztryl W126 S,SE,SEC,SEL,SD,SDL Class 6 08-19-2008 08:28 AM
    88 420SEL transmission problem william.wood W126 S,SE,SEC,SEL,SD,SDL Class 1 03-03-2006 01:54 PM
