k40 module (please help) - Mercedes-Benz Forum
post #1 of 2 (permalink) Old 09-03-2009, 06:10 AM Thread Starter
Date registered: Mar 2008
i have read lots of posts about the maf being replaced and the k40 having bad solder joints. here is my issue
the 2000 slk 230 approx 75k miles have had for 6 years the supercharger seemed to not being giving it the power it should have and the check engine light was on.
I replaced the maf with one from bosch, that did not fix the problem
i pulled out the k40 board and did see a bad joint in the upper left with a burn mark on the board, so i resoldered that joint and put the k40 back in the car
now the check engine light went out but the car stalls out at slow speeds and misses when giving it gas (hesitation) on the highway
now what can i do besides take it to the dealer ?
manifesto is offline
post #2 of 2 (permalink) Old 09-03-2009, 08:49 AM Thread Starter
ok i actually found a hose that must have come loose between taking the k40 panel off and driving one mile (a coincidence i guess ) but now car is running
    K40 Relay Module Miracle!!!! pmajet R170 SLK-Class 2 08-08-2008 09:07 AM
    Failure of ASR, K40 and Fuel Control Module KIM'SLK R170 SLK-Class 1 11-13-2007 01:11 PM
    Soft top control module on ebay (3 plug module) StuartKnight R129 SL-Class 0 11-13-2007 06:14 AM
    K40 module location solarant W124 E,CE,D,TD Class 1 10-05-2007 05:32 PM
    K40 Relay Module upstate engineer R170 SLK-Class 2 10-26-2005 07:44 PM
