My clk230 wont start!!! - Mercedes-Benz Forum
post #1 of 4 (permalink) Old 09-02-2009, 04:26 AM Thread Starter
Date registered: Sep 2009
Question My clk230 wont start!!!
Please can anyone offer any help? My car had previously done this a few times over several months and but had eventually just started ok. What it is doing is, turn the ignition to start (all lights come on and don't dim) and all I get is a heavy sounding Click (just one) and nothing. I have checked voltages at battery and starter motor and both reading 12.4, tried trickle charging the battery over night, tried jump starting, replaced the starter, cleaned up earthing strapps (even bypassed these with cables stright from the battery) Had no problems with anything prior and really don't know what to do? quite desperate now and need the car for work any help welcome
Richie1961 is offline
post #2 of 4 (permalink) Old 09-02-2009, 10:04 AM
Diesel Benz's Avatar
Quoted: 35 Post(s)
Did you measure the voltage at the starter when actually trying to start the car? Sounds like a solenoid/starter motor issue. Even cleaning & lubricating the starter motor moving parts might help (but it would need to be disassembled).
Diesel Benz is offline
post #3 of 4 (permalink) Old 09-03-2009, 02:08 AM Thread Starter
Thanks for the response. Battery level doesnt alter. I checked the starter (actually replaced it too) and its fine. the earth is fine too, however I can start it if i connect the soleniod directly to the battery terminal! Just shorting out the soleniod just produced the click, it was only via a direct connection from the battery? (if it was the other way round, negative, it would just be an earthing problem!)
post #4 of 4 (permalink) Old 01-09-2011, 02:17 PM
Date registered: Jan 2011
Vehicle: 1998 clk 230 komp and 1998 vito diesel
clk wont start
Hi, I have the same symptons with my clk 230 - did you manage to find the fault?
benzmatt is offline
    wont start lately padams3512 C208/A208 CLK-Class 1 04-17-2009 04:31 PM
    02 C240 Wont Upshift / Weird Messages / Now Wont Start jondag W203 C-Class 7 12-03-2008 08:15 PM
    NEED HELP WONT START brandon671 W126 S,SE,SEC,SEL,SD,SDL Class 10 05-26-2008 04:25 AM
    After wire harness change temp gauge wont work, and now wont start daanmuller W140 S-Class 4 06-14-2007 09:00 AM
    Start, ran, wont start again horsessmellfunny W123 E,CE,D,CD,TD,TE Class 9 09-06-2006 09:58 PM
