Changing belt on 1982 300SD TD - Mercedes-Benz Forum
post #1 of 1 (permalink) Old 09-01-2009, 09:29 PM Thread Starter
Date registered: Aug 2009
Question Changing belt on 1982 300SD TD
I am going to change all 4 of my belts on 1982 300SD Turbo Diesel, if I can figure out where the A/C compressor bolts are to loosen it? Is it possible to change the belts wothout removing the fan housing and fan?
A squeaking noise is coming from alternator and mechanic said I need a new water pump. How do we know when these need to be replaced (alt/water pump)?
If the alternator and water pump need to be replaced, I might as well do it at same time to change belts, correct?
Just trying to not have to go and take things off 2-3 times when I can do it in one day, save on coolant, time, and dirty diesel hands.Hahaha...
Thanks alot MBZ pros.Keith in California.
payment pro keith is offline
    1982 300D - looking for alt belt adj info. lxwlxw W123 E,CE,D,CD,TD,TE Class 8 03-01-2011 08:12 AM
    Value of 1982 300SD?? smallfence W126 S,SE,SEC,SEL,SD,SDL Class 14 01-23-2006 08:19 AM
    FS: 1982 300SD Vendredi39 For Sale/Wanted/Trade/Giveaway 1 12-15-2005 03:01 PM
    1979 vs 1982 300SD? chrissie10027 General Mercedes-Benz 3 09-29-2005 08:02 PM
    1982 300SD Guest (MBNZ) W123 E,CE,D,CD,TD,TE Class 1 03-03-2002 07:53 AM
