1985 300SD front seat removal, box spring replacement. - Mercedes-Benz Forum
post #1 of 3 (permalink) Old 09-01-2009, 03:13 PM Thread Starter
Date registered: Aug 2009
I had a broken spring on the front driver seat (1985 300SD), found a seat at the junk yard and decided to change the box spring as well as adding some much needed padding...
Following the info I found from other members I used a 1/2 inch rubber mat and also added some "pool noodle" to the new setting. Took me about 5hrs to complete the task, I have absolutely zero experience as a mechanic and I am confident that it can be done in much less time....
The result is spectacular, the seat now feels very firm, much more like current model vehicle.
When I was at it I took some pictures, for two reasons. First I wanted to document the removal which really help me for the re-install. Second I thought that it might be of interest to other member .
So here is my modest contribution:
MobileMe Gallery
Problem I encountered:
1)- I had hard time removing the center screw of the railing, I kept the seat connected to the electrical plugs in order to move the seat and align the center screw with the hole in the frame.
2)- Hard time re-installing the seat in the slider by myself but if you can find someone to help it should be an easy task.
1)- Remove the back seat (more space to maneuver)
2)- Once removed, place a pad or blanket under the seat while working on it. It will prevent scratches.
3)-Take lots of pictures during the tear down, very useful during the installation.
4)- Label the connectors and wires under the seat, they all look alike, making sure they are reinstalled in the right place.
5)- I used 4 inch "pool noodle", easy to install and it give plenty of extra firmness.
6)- I used some rubber garage floor pads to place under the cushion, inexpensive.
All in all, it was a great day, no bolts or screws left over after completion and the electric seat still works...
Hope this help and if I can do it, then anyone can do it, believe me....
fred98050 is offline
post #2 of 3 (permalink) Old 07-31-2013, 06:06 PM
1985300SD's Avatar
Date registered: May 2013
Vehicle: (2) 1985 300SD (1) 2 tank wvo
Aww the pictures are gone..
1985300SD is offline
post #3 of 3 (permalink) Old 08-01-2013, 01:10 AM
Date registered: Jul 2005
Vehicle: 90 300E, 99 ML430, 00 ML320, 05 E500 4matic Wagon
Quoted: 877 Post(s)
When Apple took Mobile Me offline and switched to iCloud the links to images died.
Noodles is offline
    300SD Shock Absorber Replacement, Rear Seat Removal Pauls82300SD W126 S,SE,SEC,SEL,SD,SDL Class 15 02-04-2014 08:25 AM
    new(still in box) Bilstein front shocks for 82 300sd johntksr W126 S,SE,SEC,SEL,SD,SDL Class 1 02-14-2007 08:34 PM
    300CD driver spring seat replacement Zill W123 E,CE,D,CD,TD,TE Class 1 09-07-2006 02:51 PM
    WTB seat spring for front seat Jason Lap For Sale/Wanted/Trade/Giveaway 2 11-16-2005 03:08 PM
    front spring removal gdbmj W123 E,CE,D,CD,TD,TE Class 1 07-15-2004 12:05 PM
